04-14-2016, 05:46 AM | #1 |
Rep 596
JB4 Map 6 Results
Had car in at local tuner (Performance Centre) yesterday for fitment of a Richter 200 cell sport cat running in combo with the stock exhaust. Had JB4 stage 2 installed previously and had been running Map 5 on the stock cat.
M235i RWD 8AT Edit: Running 97 ron (93) fuel Dyno Results (converted to crank hp): Stock - 316 hp/330 ft-lb Map 2 (stock cat/winter tyres) - 349 hp/ 381 ft-lb Map 5 (sport cat) - 375 hp/ 440 ft-lb Map 6 (sport cat) - 400 hp/ 417 ft-lb Wheel hp conversions beneath graph. Car feels and sounds great. Running Map 6 currently, very smooth and linear power delivery. Traction is still an issue with stock tyre widths (PSS) but pulls incredibly hard all the way to redline. Charge pipe hasn't been an issue (yet) - will swap to metal one if it breaks ofc. Intake air temps are stable around 25C max so don't think intercooler is an issue for me either for road driving. Link below is to a video of my car with the Richter 200 cell cat vs another 235i with the Richter decat in the same environment both cars with stock exhaust. Very good sound comparison! https://www.facebook.com/theperforma...9493231764258/ Last edited by allthatisntnow; 04-14-2016 at 06:52 AM.. |
04-14-2016, 04:35 PM | #2 |
Rep 190,807
Great!!
What boost setting are you using for map 6?
04-14-2016, 04:41 PM | #3 |
Rep 596
04-14-2016, 04:42 PM | #4 |
Rep 190,807
Cool, thank you
04-15-2016, 09:42 AM | #5 |
Rep 26
Tesco 99 or vpower depending where you are will probably get you more. I've had map5 targeting 17-17.5psi on just tesco 99, usually though it's about 16-17ps herei in North London. It does seem to depend a lot on where you are though as recently as trip to south Wales only yielded 14-14.5psi on T99 as ethanol content seems to vary considerably.
04-15-2016, 10:39 AM | #6 |
Rep 447
Were these results with the JB4 EWG hooked up? I have similar setup w/sport cat but using AA8 tune and was thinking about JB4, but sounds like EWG wires are a real pain to get to.
Thanks
04-15-2016, 11:00 AM | #7 | |
Rep 1,541
I used a VERY long socket extension to get to mine. Flat head would have been easier. Should only take a few minutes with the right tool. |
04-15-2016, 01:09 PM | #9 |
Rep 596
Yes, the EWG wires are installed. Didn't fit them myself though so can't comment on how tricky they are to get to. Although i have heard they are a pain due to the location. Map 5 seems to target higher boost with them fitted once its been acclimatised with some WOT runs in 3rd.
04-15-2016, 04:19 PM | #10 |
Rep 1,541
