02-19-2020, 11:17 AM | #1 |
Rep 188
M240i staggered summers fitment
What would be the max size tire I can comfortably mount on these rims with stock suspension and with at least 40 sidewall all around?
Front - 8.5x18, ET35 (5x120) Rear - 9.5x18, ET45 (5x120) I blew out my last summer so I want to up my sidewall thickness as much as possible. Thanks in advance! Ps I'd like 235/45 f 255/40 r
Modlist VRSF CP & Catless DP, CTS Intake, BM3 Stage 2 91 OTS, Customized M2 Exhaust, M Performance II Wheel, Shifter and Handbrake; Matchup7 Amp, Dinan Lowering Springs w/kit, Red Cerakoted brake calipers, Gtechniq CSL and EXOv4 + BeadMaker, Stance SF03 Gloss Black - Machine Tint (F:18x8.5 ET35 (BFG SC2s 235/45/18) // R:18x9.5 ET45 (BFG SC2s 255/40/18)) |
02-20-2020, 10:20 PM | #2 |
Rep 294
Drives: 2019 M240i Coupe RWD
Some people claim you can run 235F / 265R with wheels of your offset. The rear may have rubbing on the fenders though. You'll want 40 sidewall on the fronts and 35 on the rears. Why do you want 45F/40R? Stock was 40/35 on 18's.
02-21-2020, 05:36 AM | #3 |
Rep 706
Here... Use this to find a tire that will match overall diameter and width but have a different sidewall...
https://tiresize.com/comparison/ Regards |
02-22-2020, 12:49 PM | #4 |
Rep 2,873
I think you'll be better off dropping to a 17" wheel to run big sidewalls. For those widths with a 40 profile you'd have a bigger diameter wheel by about an inch.
