02-12-2020, 11:47 AM | #1 |
Rep 13
CPO Warranty Reality - Charge Pipe
Short story: BMW CPO warranty sucks! Replace your charge pipe with a metal one.
Long story below: I hate for my first post to be a rant, but I figured I would share my experience with others that have or are thinking of buying a BMW. Last year I was in the market for a daily driver that would be more fun to drive to work. My requirements were to be small, so it fit in my garage, have a manual gear box because rowing your own gears is the definition of fun, and be under a 5 second 0-60 car as I didn't want something that a mini van could outrun. After searching the M235i seemed to fit the bill. I found a CPO 2016 M235i basically fully loaded with 34k miles and paid $28k for it. As for the car, it is just about everything I could have wanted. Has enough power, manual transmission, small enough to fit in the garage but large enough to be a practical daily driver. I typically grab the keys to my m235i over my truck and my 911. I think this car is a hidden gem in the car industry considering the cost and driver satisfaction. As for the bad part, when I bought the car I insisted on finding a CPO car knowing that BMW doesn't have the best reliability. I did my research and knew of known problems, like the charge pipe, but figured the CPO warranty would keep me on the road and if I decided to keep the car longer then the warranty, then I would address these issues before hand so that I wouldn't get stranded. My first experience with the CPO warranty was a surprise as I didn't know you had to pay $50 for each warranty service. So the CPO warranty is really a warranty with a $50 deductible. Not a big deal, but also not anything I've experienced from other companies (only experience with Porsche). So I had them look at the IDrive that had a sticky switch and some trim that was falling off. Their response was it was wear and tear and wasn't covered. Great, out of $50 and still had to fix myself. I guess my expectation was that buying a CPO car everything would be working 100% correctly when I took purchase. I now consider this a learning experience about buying out of state sight unseen. This brings me to today, about 9 months of ownership. Driving down the interstate at around 65mph, I push the throttle down about half way an hear a pop. First thought it my mind, charge pipe. Sure enough I stop at where I'm going, and see that the charge pipe broke off the intake. No big deal, put the charge pipe back on by hand and drive to the local dealer to get fixed under warranty. Fast forward to this morning where the dealer calls me and tells me they can't fix the charge pipe under warranty as the CPO warranty doesn't cover any plastic parts in the car. SAY WHAT!!! Yeah, so that warranty I had really doesn't cover much at all. For some reason I thought that the CPO warranty covers the same things that the original warranty covers. This has really changed my mind about BMW. Yes, they make great cars. No they don't stand behind them. If you plan to buy one, factor in the cost of BMW not standing behind their product or warranty. I guess this is why the resale is below average. Moving forward I plan to keep my car for another few years. I'll do the charge pipe and inter-cooler upgrade so that I don't get stranded in the future and I'll also be pro-active on any other issues as I know my warranty isn't worth much. Half the parts in car are made of plastic and none of them are covered. I still love the car, but I can't see buying another one with the current attitude of BMW. So for those of you thinking about not worrying about your charge pipe because it is under warranty, you might want to think about that again. My car only has 41k miles on it now and was being driven in 50 degree weather when it blew. I live in GA, so no extreme hot or cold climate. I wasn't under full boost when it failed and the car is 100% stock. |
02-12-2020, 12:13 PM | #2 |
Rep 52
That sounds crazy.... Did they show you anything in the written policy as a basis for denying the repair?
I don't see anything in here that excludes the charge pipe: https://cpo.bmwusa.com/Content/docs/...NotCovered.pdf Maybe plastic trim parts aren't covered, but the charge pipe is a non-consumable piece of the engine. It isn't a wear-and-tear part either. Did you try another dealership? |
02-12-2020, 12:33 PM | #3 |
Rep 674
Talked to my BMW Richmond VA service manager about getting Down pipe added and the cheap Chargepipe. He said best to switch out chargepipe at same time (we knew that).
I have a 2016 235i CPO, he says if it blew stock its covered, if I added the Downpipe, he'd have more difficult time but would work for me. (actually injectors bigger concern) But maybe including under the following: https://cpo.bmwusa.com/Content/docs/...NotCovered.pdf rubber engine and heater coolant hoses, vacuum hoses (including clamps and connectors); tires; Call the BMW complaint number, weak they wouldn't cover a known item Last edited by 4Hockey4; 02-12-2020 at 12:41 PM.. |
02-12-2020, 12:40 PM | #4 |
Rep 13
Thanks for the heads up guys! I'll reach out to BMW USA tomorrow to confirm. Flying out of country tomorrow for some R&R. Luckily this isn't my only car so no problem to let the m235i sit while I work things out. I'll keep this thread updated with my findings.
02-14-2020, 10:30 AM | #5 |
Rep 30
Based on the specific list of CPO exclusions, the charge pipe should 100% be covered by the CPO warranty. A charge pipe is not a coolant hose or a vacuum hose, and in fact it's the opposite - it contains pressurized air. Your dealership is confusing the CPO not replacing rubber parts in the engine and claiming that means it doesn't cover a plastic charge pipe as well. A sticky switch should also be covered, though loose trim pieces would not be covered.
You've been going to an awful dealership that's refusing valid warranty work. I would strongly recommend taking the car somewhere else in the future that will actually bother to read the details of the CPO warranty instead of being lazy. |
02-15-2020, 07:12 AM | #6 |
Enthusiast
84
Rep 229
Sounds like terrible dealer service to me. I could understand if modified, but stock...should be covered. CPO is a different animal though, and I would never recommend the maintenance plan!
_______________________________________
2016 M235i XDrive Estoril Blue/Black |
02-15-2020, 07:29 AM | #7 |
Rep 36
My car is CPO. My charge pipe was covered. However they covered it under the emissions warranty and I had no deductible. But they said CPO would have covered. They used emissions warranty to save me the deductible. They covered towing it about an hour to the dealer as well.
02-15-2020, 09:25 PM | #8 |
Rep 213
When I worked at my local BMW dealer we looked for ways to help the customer; unfortunately, some dealers take the opposite tact- looking for ways to deny coverage...
2014 M235i
2015 X1 xDrive28i M Sport 2009 Cooper Clubman 1999 Wrangler Sahara 1995 318ti Club Sport |
Dylan861330.00 |
02-17-2020, 09:14 AM | #9 |
Rep 422
Every one of these I've had has had the charge pipe blow in hot weather.
Even under CPO, being such a huge common fail item, it should definitely be covered. |
02-17-2020, 02:40 PM | #10 |
Rep 230
Drives: 2018 240i
Warranty’s
My 48 months is about up and will have no warranty ? So does any one buy an extended warranty or just take your chances ? Or get a new car ? Just curious when read stories like this. I can replace the charge pipe don’t need dealership but the stranded on the side of road part I wouldn’t like much. I am 63 and have never been stranded with a vehicle in my entire life....Bmw is going to change this for me ? I hope not
Hap |
02-17-2020, 03:38 PM | #11 |
Rep 3,490
That argues for changing it now to one of the aftermarket upgraded units.
02-18-2020, 01:54 AM | #12 |
Rep 6
side note, does anyone think CPO would cover faulty ignition? Got stranded in the middle of nowhere today for 6 hours, got an error message "Ignition/starter malfunction".
02-18-2020, 02:20 PM | #14 |
but no flokka
523
Rep 717
When I had my F30 the charge pipe blew itself practically in half, CPO covered it 100%. I also didnt have to pay a dime for it. That was the first and last time id ever buy a used car though... i dont like not knowing what a car has been through before it was mine.
02-18-2020, 02:46 PM | #15 |
Rep 8,942
My car is still under the original warranty but I blew my CP and it was replaced for free and I have Dinan Stage 2. Wasn't even a discussion the dealer came and got my car on a flatbed, fixed it, returned it on a flatbed no questions asked. I did not even have to leave my house.
Dylan861330.00 |
02-25-2020, 08:54 AM | #17 |
Rep 269
I had an E46 ZHP, and it developed the "VANOS rattle". I had CPO and left it with the dealer while I went on vacation. When I got back, they said they didn't fix it because they needed to first replace the "oil dipstick" or something and that wasn't covered by the CPO. I find ALL 3rd party warranties thoroughly useless, including the CPO garbage which you pay a HUGE premium for.
02-25-2020, 12:11 PM | #18 |
Rep 13
Finally got to follow up on this as I was on vacation and then came down with the Flu.
After talking with BMW USA, they reminded me that my car still has 3 months of the original warranty and that the charge pipe is defiantly covered under the original warranty. I called the dealership, Global Imports in Atlanta, and told them this and they apologized and said they would have it fixed by the end of the day. On a side note they said the coolant needed to be changed as it didn't test well. Not sure if they are just a dealership trying to make money off service or if it really needs it (2016 car with 41k miles). Either way, I'm not giving them my business. I did call BMW USA back to clarify if the charge pipe was covered under the CPO warranty. We went through the long list of things that are not covered under the CPO warranty that would have been covered under the original warranty. Anyone who thinks they are "safe" with a BMW CPO warranty should read this list first. Even the customer service rep was surprised about how much is not covered. At the end of the day, it did look like the charge pipe is not excluded, but no where does it state that it is included. I feel this is just a legal way that allows BMW to have a lot of gray area to deny claims. Anyways, BMW USA said that if I run into a similar issue again with the CPO warranty to give them a call and they will try to resolve. I give the customer service agent a A for trying to help but I give BMW a F for failing to take care of the customer. With a know issue on the N55 of the charge pipe failing, it should be front and center no questions asked covered under warranty to keep your customers happy. I work with national brands and it is a no brainier to take care of customers on known issues so that you don't piss off your customer and their 100 social media followers. Thanks for everyone's comments. I still plan to keep my M235i at least until it gives me problems again. I'll be a little more proactive on known issues so that I don't have to rely on the CPO warranty for the next year. Overall the M235i is still supposed to be very reliable and as long as it doesn't become a problem I'll keep it in my garage. My idea to upgrade to a M2C is shot though. At these price points there are other companies that are much more willing to go our of their way to keep their customers happy. It is too bad though, as the car is a great car. Maybe BMW will hire a CEO that puts customers first. |
02-25-2020, 02:27 PM | #19 |
Rep 422
Smart on your part.
02-26-2020, 02:33 PM | #21 |
Rep 30
The CPO warranty does not have a list of what it covers, it only has a list of exclusions that it does not cover. If it is not on the list of exclusions, then it is covered by the CPO warranty. Because the charge pipe does not appear on the list of exclusions, it is covered by the CPO warranty.
02-26-2020, 04:23 PM | #22 |
Rep 5,364
I get that you're upset, but please name me a car company that makes performance cars that doesn't have some type of history of giving people the run-around when problems happen. I spend way too much time on various auto forums and there are horror stories everywhere. Audi, VW, Ford, GM, Nissan, Subaru, and BMW are all pretty good at giving owners hell sometimes or placing the blame elsewhere.
Poochie9103.00 |
