2Addicts | BMW 2-Series forum Technical Topics DIY and Coding Discussions Most suitable OBD
      01-13-2020, 03:25 PM   #1
DrivingPassion
DrivingPassion's Avatar
Drives: '15 M235xi
Most suitable OBD
I've been using OBDFusion for my E46 but it does not pick up the right data from the right cylinder banks for my M235xi.
What are the most suitable OBD device you have used successfully?
The hardware OBD device I'm using is the Veepeak BLE.
2015 M235i xDrive 8AT
      01-14-2020, 02:22 AM   #2
ngl
ngl's Avatar
118
Drives: BMW 228i
I'm using OBDLink SX, permanently installed in the car, but for data logging on the track. Can't say how it would work on your use case.
Quaife LSD | BC Racing Coilovers | H&R ARB | F8x LCA+TS | Wiechers Strutbar | Mishimoto CAI | Mishimoto Oil Cooler | Mishimoto Oil Catch Can | Mishimoto FMIC | VRSF DP | Masata TIC | Masata CP | DV+ | Custom Kline Exhaust | GTS Style Roll Cage | Sparco Evo QRT | Brey-Krause seat mounts | Schroth Profi 2 ASM 6p | 10" Android HU| xHP Stage3 | BM3 | RaceCapture Data Logger
      01-14-2020, 07:55 AM   #3
DrivingPassion
Drives: '15 M235xi
I'm thinking more of using it for diagnostics of technical issues in the future. One of the things which I'd like to pick up from the OBD is the Short/Long Term Fuel Trim from both cylinder banks.
Does your OBD device pick up those consistently?
      01-29-2020, 02:54 PM   #4
DrivingPassion
Drives: '15 M235xi
TTT
      01-31-2020, 08:41 AM   #5
MarcoZandrini
Drives: 2018 M240i
OBDFusion has to be configured for wide band oxygen sensors. Go from there. Also, reach out to the app developers as they are very responsive to inquires and suggested improvements.
      01-31-2020, 10:09 AM   #6
DrivingPassion
Drives: '15 M235xi
I did contact them and here are responses:
Thanks for reaching out to us! Vehicles typically support a subset of the SAE PIDs available over generic OBD2. If you're not seeing values for the PIDs, your vehicle likely doesn't support these PIDs. I'm sorry that I don't have better news!
There are also some O2 sensor voltage wide range (Bank X, Sensor X) SAE PIDs available. If these are supported by your vehicle, they'll be available in the PID selectors when you're connected to your vehicle.
