01-05-2020, 05:21 PM | #1 |
Rep 60
Difference between B58 in M340i and M240i?
The B58 in the 3 series makes more power than the one in an M240i.
Is it just tuning, a bigger turbo, both, or ??? |
01-05-2020, 10:42 PM | #2 |
Rep 86
01-06-2020, 03:06 PM | #3 | |
lurker
24
Rep 130
01-06-2020, 03:30 PM | #4 | |
Rep 86
This wiki page has all the different variations of the b58 and which cars they belong to. |
01-06-2020, 04:38 PM | #5 | |
lurker
24
Rep 130
I realize now OP is talking about the 2020 M340. I was thinking B58 from 2016-2019 340, same motor as m240... |
01-06-2020, 10:45 PM | #6 |
Rep 706
The wiki and other sites really don't break it down... All I've read is the S58 upper end (intake, valves, turbo) is totally different from the B58 as well as the exhaust. Would love a precise breakdown including timing and valve lift details, lol. But even if you could get the parts and do a top/swap, not sure you'd get support, you'd be on your own (tuning, dialing it in).
A better question would be to define the differences between the B58B30M0 (M240i) and the B58B3C (Supra)... BM3 tunes show a significant difference in HP between the two, with same mechanical mods, 40HP difference... Is significant enough that typically cannot be achieved without some physical/mechanical changes. There probably is some "down tuning" going on, in the name of safe tuning, lol. Just a guess until identifying some engine differences. I think the Supra modding groups will bleed information over to the M240 as it is the same engine but a more active group currently. Regards |
01-08-2020, 12:45 AM | #7 | |
Rep 213
https://f30.bimmerpost.com/forums/sh....php?t=1680853 |
01-08-2020, 05:18 PM | #8 | |
Rep 60
01-09-2020, 11:29 AM | #9 | |
Rep 706
A fairly easy upgrade to address the fueling limits. Already recognized by BMW in the TU1 (update) and seems to answer the difference between the two I've been looking for. Thank you! There some other items from the Supra design I'm watching, especially that 1,000hp build. Anyways, another link (better than just the Wiki which really doesn't spell out the components of the engines or the differences). https://bimmerlife.com/2018/11/01/b58-engine-technical-update-brings-388-hp/ Enjoy |
01-09-2020, 11:48 AM | #10 | |
Rep 2,026
01-09-2020, 06:30 PM | #11 |
Rep 706
Part numbers don't tell you diddly... What page on real OEM defines the specs for the Turbo, or the Fuel Pump, by part #...?Thank you, but the site doesn't do that. It doesn't provide the specs on a cam, or compression ratio on a piston. Realoem is awesome in its own way, that yes, you can identify parts, even by pictographs, and obtain the corresponding part # and then chase it down.
That page link by the way, describes in detail the difference between the two fuel pumps. And the specs it notates on the HPFP is spot on. Regards |
01-14-2020, 07:57 AM | #12 | |
Rep 2,026
That article you linked to was written last year and it proves my point. None of the numbers match the actual latest variants for 2019 and 2020 after the B58 TU (technical update). The B58 TU resulted in the B58B30O1 and the B58B30M1. The original B58 engine pdf breaks down the naming nomenclature: https://www.1erforum.de/attachments/...ine-pdf.84135/ B58B30A/B58B30M0 - M240i B58B30B/B58B30O1 - US Spec Z4 M40i/M340i - 11002464415 B58B30C/B58B30M1 - Supra and many others as of 2019+ - 11002463592 Here is an actual BMW press release for the Z4 M40i which has the B58B30B variant engine for all production months. https://www.press.bmwgroup.com/globa...the-new-bmw-z4 And the technical specs it links to: https://www.press.bmwgroup.com/globa...84770EN/442425 The largest variation between these two engines is that B58B30C uses an integrated exhaust manifold and cylinder head (dubbed a "headifold"). Details of the B58 TU updated engines can be found here: https://f30.bimmerpost.com/forums/at...4&d=1565745080 Comparing the BMW academy docs will help pinpoint some of the differences between the B58 variations. Even those docs are full of marketing talk. A lot of the time they re-iterate normal bmw technology as if it's all new and special for the engine being discussed. Point being... The "leaks" that the blog you linked to did not end up being entirely accurate. Even all the wiki pages have a lot of bad information. Mostly they all reference back to random european auto blogs. Even further complication is that the US and EU are now getting different engines to meet the latest EU emissions. The Supra/EU Z4 B58B30C seems to be more capable in stock form but it's an overall more restrictive package that is oriented around EU emissions. Nothing you can bolt on to a regular M240i and go faster. There are factual sources available to us.... BMW academy docs, Newtis.info, Realoem, BMW's subscription based online system, Rheingold, etc.... Once you have a part number from Realoem you can use that to get the technical details through various BMW systems. The big differences would be between the A/B/C engines. Each of these engines have sub-categories of trims/power levels but the hardware is the same. Last edited by bbnks2; 01-14-2020 at 10:40 AM.. |
JD11937129.50 |
10-26-2021, 08:02 AM | #13 |
Rep 8
Drives: BMW 135i Coupe (N54)
thanks for the ifno guys!
My question would be, how to know what version of B58 my m240i 2020 has? I read the wiki page and it skips from 2017-2019 to 2021 without mentioning the year 2020. Is there a way to use the VIN code to figure it out? thanks!!! |
10-26-2021, 09:12 AM | #14 |
3626
Rep 3,592
All F22 M240i have the B58B30M0 engine in 250kW/500Nm guise for all model years.
10-26-2021, 11:04 AM | #15 |
Rep 166
Drives: '21 EB 240, G87 M2 (preodered)
Yep, what aero said - the only difference that wouldn't even apply to you is 240s (or I guess all BMWs for that matter) built after 06/2020 have the new DMEs. But I think by then, they'd all be model year '21s
2021 EB M240 6MT: TC Kline Camber Plates & Coilovers, Eventuri CAI, AA Catted DP, Remus Non-Res Catback, FTP CP; M Front Lip, Rockers, Mirrors, Spoiler, Interior
DTremens1.00 |
