05-02-2024, 02:14 PM | #1 |
Rep 7
Need help flashing used FEM
Hello, I'm trying to flash used FEM after replacement on BMW F22 LCI 230xi and I'll try to explain the problem I'm having.
The car had water damage so I replaced modules like FEM, REM, TBX, GWS, ASD, DSC, AMPH, ATM. The used FEM already has VIN and Keys written in it so the car starts and runs. But the problem I'm having is the car is not communicating with few modules like: AMPH, ICAM2, LMV_FR and few other that shouldn't even be in this car: EME, SME, TFE, LIM/SLE So I thought about flashing FEM_BODY and FEM_GW with E-Sys to see if it will fix the problem, but when I do TAL calculation before flashing I get warning: 3 TAL lines have been set to status "NotExecutable" during TAL calculation. [C384] LMV_FR Missing SWE: btld_00001d89-161_046_002 cafd_00001543-000_054_009 swfl_00001d8e-001_054_002 swfl_00001d8d-000_054_002 2 WARN events during TAL generation [C383] [] Warning 1680, no application data list available for ECUId:SME2_0x07 [] Warning 1727, TAL-Lines for ECU ECUId:LMV_FR_0x19 where set to NOTEXECUTABLE because a necessary BL-Update is NOTEXECUTABLE I Tried VO coding all the replaced modules but it didn't help. Any ideas how should I approach this? I also found out that I can edit the SVT_soll and remove the LMV_FR part. Is it ok to do so would it be ok to flash FEM this way? |
05-30-2024, 10:39 AM | #2 |
Rep 135
Did you Virginized FEM ?
F30 : 322, 323, 3AG, 508, 6WB, Full System Bowers Wilkins, ID6 with CID Touch, RSE ID6
G05 : 2VW, 2VH, 3AK, 3E3, 5AU, 5AR, 5DN, 6F1, 610, 7M9 |
