11-08-2020, 07:23 PM | #1 |
Rep 9
Pro-active battery replacement?
My 228i xDrive is coming up on 4 1/2 years/60,000 miles. Given how sensitive the electronics seem to be, does it make sense to replace the battery or wait until it dies and risk god knows what.
Never had to worry about this in my 1969 Plymouth... |
11-08-2020, 07:54 PM | #2 |
Rep 6,027
I had the same thoughts and replaced mine at 5 years. The need is lurking out there. I just chose to manage it before it surprised me.
11-08-2020, 07:57 PM | #3 |
Rep 218
Before winter sets in is a good time
to check battery health. Make sure it’s been run recently (not sitting around for days, and put on the headlights for a few minutes to take off the surface charge, turn them off, and measure battery voltage a few minutes later. If it’s less than 12.2 (or slightly lower in cold temperatures, you should probably replace it. Here’s more detailed info. https://www.aa1car.com/library/2003/us20310.htm |
11-08-2020, 09:06 PM | #4 |
Thaumaturge
181
Rep 211
I agree. The last thing anyone needs is to go to start the car on a bitter cold day and for the battery not to be up to the task.
Replace the battery now and it will be good for the next 5 years. It's good insurance. I got an AGM Odyssey 94R-850 Battery from BatteryMart.com. Great price and lightning fast free shipping. And I used Carly to register it. Note that the battery in my 2014 M235i was the larger one that is spec'd for the convertible. Either battery will fit as the mount is made to handle both the larger and smaller one. If weight makes a difference, go for the smaller one. If you just want a bit more capacity, go for the one for the F23. ///Rich Last edited by Rich.Wolfson; 11-09-2020 at 09:42 PM.. |
shadowfax1289.00 |
11-08-2020, 11:33 PM | #5 |
Rep 130
I replaced mine at 112k miles and six years of ownership. Had no issues with the battery.
I decided to keep the car as long as it runs. Changing the battery now seemed a good choice since I will not likely need a third battery anyway
[FONT="Arial"] M235i 6 speed, MGM. Wavetrac LSD with altered final drive ratio, MPE, MPK Airbox, side skirts, diffuser, Dinan springs, LCAs.
11-09-2020, 04:08 PM | #6 |
Lucky13
211
Rep 1,762
I have the original battery on a 2014 so 6 and 1/2 years and its going strong. Once a week I put the BMW battery tender on it overnight but it generally turns solid green in a couple hours. I have less than 20,000 miles on the car so the battery is holding up great.
1995 325i, 1996 328ci, 1997 528i, 1997 Z3 2.8, 2000 528i, 2001 X5 3.0, 2001 330i Convertible, 2002 M3 Convertible, 2003 M3 Coupe, 2004 M3 Coupe, 2004 Z4 3.0, 2004 X3 3.0, 2007 X3 3.0, 2007 335i Convertible, 2013 X1 28 sdrive, 2014 M235 manual, 2020 X3 30i Xdrive
11-09-2020, 04:17 PM | #7 |
Rep 44
I also have the original battery on my 2014 with 54k miles. I've never had issues with it.
I believe Costco is the cheapest place to obtain a good quality replacement (last I checked it was <$200 for an Interstate MTX-49 H8) |
11-09-2020, 04:54 PM | #8 | |
Rep 3,496
11-10-2020, 08:14 AM | #9 |
Rep 22
11-10-2020, 09:27 PM | #12 |
Rep 1,115
I have a December 2013 build M235i, I looked into the battery a few months back and from what I can tell the AGM batteries will last upwards of 10 years. Mine turned 7 right around now so I'm seeing if this winter kills it or not.
Your 4.5 year old battery is pretty safe and probably doesn't need replacement. |
shadowfax1289.00 |
11-11-2020, 06:20 AM | #13 |
Rep 1,219
Drives: 2015 M235ix
If a battery is showing a good charge, is there any reason to replace it proactively?
Is there a part for which this move makes sense on this car? The charge pipe may be one, though most of the failures happen when the engine has been tuned. It might make sense to just replace the charge pipe when doing a tune. Anything else? I do sometimes think, though, that I have reached an age when proactive replacement might be a good idea. So far, my wife has not made any moves in that direction. |
11-11-2020, 08:32 AM | #14 | |
Enthusiast
84
Rep 229
Good woman!
_______________________________________
2016 M235i XDrive Estoril Blue/Black |
11-11-2020, 04:49 PM | #16 |
Rep 2,214
Did mine at year 5 (2014 build MY15) this spring. For $250 or so it's great peace of mind. Got a 5 year free replacement quarantee to use if needed, otherwise for me it's a 5 year life cycle. I hate getting stuck or stranded with a dead battery, so preventatively changing it can keep you out of trouble.
11-23-2020, 08:26 PM | #17 |
Rep 9
12-21-2020, 09:31 AM | #18 | |
TwinTurbo Top Hat
22
Rep 252
AW 2008 135i - Auto, Prem, with Sat Radio
BMW CCA # 417107 |
12-21-2020, 12:05 PM | #19 | |
Rep 615
You always get a lot of anecdotal input to these battery threads, but one person's situation may be different from your own. So in the end we each have to make the decisions we are comfortable with in our respective situation. Batteries are not cheap, but neither are tow trucks. |
12-21-2020, 09:44 PM | #20 | |
Thaumaturge
181
Rep 211
Thanks I try to post about what I know will be helpful.
///Rich |
01-02-2021, 09:21 AM | #21 |
Rep 860
In the pre AGM battery days I would automatically replace the batteries after 5 years as a preventative measure. But I'm hearing AGM batteries tend to last much longer (no doubt you can kill an AGM after 6 months if you are determined to) and many people are replacing them after 8 or even 10 years as a preventative measure.
Thoughts? |
01-02-2021, 09:51 AM | #22 | |
Rep 198
bobkat09151.50 |
