Factory Nav screen hack DIY for JB4/ MHD guages and DashCam |
09-29-2018, 02:30 AM | #1 |
Really Twisted
28
Rep 265
Hey yall, this is my first documented DIY for my 2015 M235i F23 (still in progress of putting together and installing, just wanted to get a thread going)
Back Story: Since I first met some random dude named Christian at SoCal Euro and fell in love with his F22, I felt I needed it in my life but wanted a drop to. I bought my little blue demon, aptly name Succubus, in April 2018 and by July 2018 i was full bolt on with JB4 then in September 2018 i caved and bought MHD to run JB4 BEF. However the my M235i doesnt have a lot of dash real estate to mount an android device to run the guages and programs needed by MHD and JB4 and it didnt come with a back up csmera so here is stock looking solution to having a Backup Camera and over-riding the factory Nav screen for the guages. I also wanted to JB4 board into the car to lower the risk of water damage and clean up the engine bay. Computer Goals: ○ Run JB4 and Guages on factory nav screen ○ Run MHD program and flash/code from computer ○ Run DashCam program and serve as storage site for dash camera files ○ Run E-Sys program for coding (need to find windows emulator) Materials (you may be able to find this stuff cheaper but I love amazon so most is from there): Car Video Interface Multimedia Adapter for BMW and Mini (necessary to over-ride the factory nav screen to show android OS/Computer and Apps) comes with BimmerTech MMI backup camera but can get bought seperately. - $200+ Example: https://www.amazon.com/Interface-Mul.../dp/B06XC3VM9M Computer: PINE A64+ 1GB BOARD - $19.99 LINK: https://www.pine64.org/?product=pine-a64-board-1gb PINE64 WIFI 802.11BGN/BLUETOOTH 4.0 MODULE - $9.99 LINK: https://www.pine64.org/?product=wifi...oth-4-0-module Supplies: 6-Circuit Blade Fuse Block With Thumbscrew Cover with 6 ground connections (for the power/negative circuits needed for PC and Dash Cam, with room for more circuits) - $24.99 LINK: https://www.amazon.com/gp/aw/d/B07CLWBSNJ Wireless Mini Handheld Keyboard with Touchpad Mouse Combo - $15.99 LINK: https://www.amazon.com/gp/aw/d/B01CE70TZC Dash Cam Hardwire Kit - Micro USB (Power supply for computer that has a low voltage cut off so battery doesnt drain if left unattended for over 24hrs) - $9.95 LINK: https://www.amazon.com/gp/aw/d/B00S73FE8A Samsung 64GB MicroSD (for OS and app storage, may use any size over 8gb I think, I went larger so that the dash cam can store recording on it) - $15.99 LINK: https://www.amazon.com/gp/aw/d/B06XX29S9Q USB 3.0 Hub with 4 USB 3.0 Ports - $7.99 LINK: https://www.amazon.com/gp/aw/d/B01N8VSKLY JB4 Extension: Db25 Male D-Sub Crimp Type Connector (5-Pack) - $2.30 LINK: https://www.amazon.com/gp/aw/d/B007R2JHQM D-Sub Male Standard Crimp Pins, (100/Bag) - $3.85 LINK: https://www.amazon.com/gp/aw/d/B007R2JEI8 Db25 Female D-Sub Crimp Type Connector (5-PACK) - $2.30 LINK: https://www.amazon.com/gp/aw/d/B007R2JHB2 D-Sub Female Crimp Pins (100/Bag) - $3.85 LINK: https://www.amazon.com/gp/aw/d/B007R2JDWU Pro Gray Plastic Hood For DB-25 Pin Connectors - Short Screws (5-PACK) - $2.23 LINK: https://www.amazon.com/gp/aw/d/B007R2JG3G 20 gauge wiring as per Terry at BMS. Can use any colors as long as each wire in labeled correct and pinned correctly. I bought generic 2x packs of 20g black/white/red 10 feet (planning on cutting the 10ft into 3 feet sections and just labeling and trimming as necessary once wiring is through the firewall) - $8.98 x 2= $17.96 LINK: https://www.amazon.com/gp/aw/d/B01MQPR9ZB Expandable Braided Sleeving (25 feet) - $8.99 LINK: https://www.amazon.com/gp/aw/d/B074LVPH3J TOTAL COST(not including MMI interface box because mine is packaged with bimmertech rear camera): $146.37 + Shipping as applicable
2021 Jeep Gladiator Rubicon
2015 BMW M235i F23 - Sold |
09-29-2018, 11:27 AM | #2 |
Rep 643
Subscribed.
Did you consider something like this? https://www.aliexpress.com/item/2018...ceBeautifyAB=0 Alternatively there are full android solutions built into 10.25 screens.
M235i rwd 6mt
09-29-2018, 12:16 PM | #3 | |
Really Twisted
28
Rep 265
Plus with this I can(if i can find an emulator) run windows and Esys for coding and connect my dash cam to it. I'm also looking for a usb camera that I can run some dash cam software and place the camera in the spot where the compass is located in the mirror so I have front and back covered
09-29-2018, 05:18 PM | #4 | |
Rep 643
09-29-2018, 06:55 PM | #5 |
Really Twisted
28
Rep 265
If that's true, then thatll be good for someone else to try
