03-26-2020, 09:15 PM | #1 |
Rep 61
BMS intake question M235i
Hi,
my mechanic installed me this intake and now i can hear my turbo spooling how come now i can hear it and before i couldn't it sounds amazing like a blow off valve sound !! For the people that have it how do u guys find it? https://burgertuning.com/products/bm...ormance-intake |
03-27-2020, 09:11 AM | #2 |
Rep 736
Drives: Lexus RC F
Love mine as well. My only complaint is the car almost stalls on cold starts.
Estoril Blue E36M3
03-31-2020, 11:27 AM | #4 | |
Rep 190,750
If you are also using a Jb4, disconnect the sensor on the intake and the issue will be fixed
03-31-2020, 04:44 PM | #5 |
Rep 2,214
Have had mine on for 3 years now, on the third replacement filter. The sound is worth these alone imo, plus for an open intake they look relatively "low key" as opposed to the "snake" style piped units. Like how it's molded plastic also...
04-01-2020, 10:59 PM | #7 |
Rep 190,750
Did you disconnect the sensor?
04-04-2020, 11:20 PM | #10 |
Rep 12
CEL, rough idle/cold starts are likely due to a dirty MAF sensor. It's most likely because of the oil from the filter, but also be careful not to touch the sensor when you take it out.
Get a MAF sensor cleaner and clean the sensor. If you're still having problems I would wash the cone and apply less oil. If problems persist idk man since you have a JB4, you could unplug the MAF sensor and just use the o2 sensor? It would not cause any errors in your ECU. Good luck and stay safe in NY! |
04-07-2020, 11:35 AM | #11 |
Rep 190,750
not sure whats the point of the bump. Your question has already been answered.
Use a Jb4 and disconnect the sensor, that's how you can fix the issue or you can put a closed intake instead
Zyzzthetic146.50 |
04-16-2020, 09:31 AM | #12 |
Rep 61
haha
i tried for 1hour with my dad to disconnect the MAF sensor and we were not able to.I watched some utube videos they seem to do it easily but i cant do it. Do you know how that connector unplugs or got a demo how to unplug it. It seem like mine is stuck we tried with lot of tools no success fuck !!! |
04-16-2020, 09:45 AM | #13 | |
Driver - Autocross
74
Rep 178
16 M235xi 8ZF Black on Red FBO: Xhp trans tune -BMS Intake - VRSF Catless DownPipe - VRSF CP - VRSF Muffler delete/resonator - n22 plugs - MHD stage 2+ 95map - Wagner EVO II Preformace IC - Rear seat delete - weight reduction/stripping -FTP 18.5in rims - Hawk HPS front pads - StopTech STR 660 fluid
04-20-2020, 02:04 PM | #16 |
Driver - Autocross
74
Rep 178
You can also unscrew it dude. Take the entire housing out.
04-21-2020, 07:34 AM | #17 |
Rep 2,214
Push the sensor into the housing firmly. Then pull back the small finger nail tip sized tab at the top of the connector, this will release the plug. If you have to force anything, you're not doing it right.
04-21-2020, 09:49 AM | #18 |
Rep 61
ok imma try again this weeknd
If i remove it completly by unscrewing the thing it will leave a hole and dirt will get in thats a bad idea !!! Ok Dylan thanks imma try that again !! |
04-21-2020, 12:18 PM | #19 |
Rep 5,369
Just a few kind words of advice. If you had to have someone install an intake and you're having trouble removing a connector, it may be best to leave the work to someone more seasoned or at least have them show you so you can learn.
BMW connectors can be finicky and each one has a special trick to unlock them. For connectors such as the MAF, you may need to use a pick tool to disengage the clip from the opposite side of the tab you're pushing down with your finger. The trick is not to force anything because if you break the connector, you're in for a headache. Lastly, the BMS intake is well known to cause all sorts of driveability issues including stalling and rough running conditions. It's never been shown to make power and I would say it's likely to make less power than the stock intake when driving in hot conditions. |
04-21-2020, 01:01 PM | #20 |
Rep 3,496
I know from my own experience that this is excellent advice.
