2Addicts | BMW 2-Series forum BMW 2 Series (F22) Forum BMW 2 Series Coupe and Cabriolet (F22/F23) General Forum M235 lowered on 19s ?
      03-07-2020, 02:07 PM   #1
Conntron
Conntron
Conntron's Avatar
Drives: Bmw M235i
Hey just wondering if anyone has lowered their M235 with 19 inch rims ? Curious if any issues with rubbing. Also what setup was used and thoughts on it. Thanks guys !
      03-09-2020, 03:19 PM   #2
Liandri
Liandri's Avatar
Drives: 2016 M235i
After reading every thread multiple times over the winter....et43 front 8.5" and et50 rear 9.5" are the ideal offsets if running 235/35 and 265/30. You'll see alot of 2ers on et35 and et45 with 225/35 and 255/30 but there isn't much sidewall left on that fitment. Im ordering vmr 710s in et45f and et50r and using a 3mm spacer in the front to get et43. Off the shelf solution.
Edit- doing dinan springs and from my research there won't be any rub. Can't say if that's true with springs that go lower
      03-14-2020, 11:39 AM   #3
Conntron
Conntron
Conntron's Avatar
Drives: Bmw M235i
Ttt
      03-15-2020, 07:19 AM   #4
MassNerd
MassNerd's Avatar
Drives: 2019 M240i Coupe RWD
There's nothing special about 19" rims. You reduce the sidewall of the tire and end up with the same overall diameter. Read up on fitments that work with the springs you're planning on and you can easily adjust the tire size between 19" 18" or 17".
      03-16-2020, 09:02 AM   #5
morphomeman
morphomeman's Avatar
593
Drives: 2015 M235ix
2016 BMW X3  [0.00]
2015 BMW M235ix  [0.00]
OP: What is your goal in fitting 19" wheels?
Remember that your chances of tire and rim damage increase geometrically with every added inch in wheel size. So if an 18" wheel is twice as likely to incur damage as a 17" wheel, then a 19" wheel is four times as likely.
If you go with 19", you may need to carry two spares!
      03-27-2020, 08:47 AM   #6
Conntron
Conntron
Conntron's Avatar
Drives: Bmw M235i
Already on 19s :/
      03-28-2020, 02:04 PM   #7
seansurfn2
Drives: 2014 M235i m-sport
Originally Posted by Conntron View Post
Already on 19s :/
i took off 19s and put 18s on with more meat on them. best thing
i ever did.. car handles amazing and i dont feel every single bump on
the road.. just my .02
      04-01-2020, 10:35 AM   #8
Conntron
Conntron
Conntron's Avatar
Drives: Bmw M235i
Already on 19s :/
Was ride way worst with it lowered and 19s then just 19s ?
      02-04-2021, 04:13 PM   #9
Conntron
Conntron
Conntron's Avatar
Drives: Bmw M235i
Ttt
Pic of my car for attention
      02-05-2021, 09:23 AM   #10
makrop
makrop's Avatar
Drives: '18 M240i 6MT MGM/CR
19" VMR 802 w/ Dinan Springs
I have 19s and lowered on Dinan springs and bumpstops. No rubbing or issues whatsoever.
Specs: VMR V805 19x9.5 ET45 255/30/19 / 19x8.5 ET40 225/35/19
An an obligatory picture. I still have not done a proper shoot... depressing.
Edit: totally just realized you already did this and revived the thread to update... whoops. Looks great!
18' F22 M240i | 6MT | MGM/CR
02' E46 325i | 5MT | SBM/B (beater - 200k+)
10' E82 135i | 6MT | BSM/CR (sold)
03' E46 330ci | 5MT | JB/B (sold)
      02-05-2021, 09:04 PM   #11
TheSniper
Drives: M235i xDrive
I having the Dinan springs and 19's and have no rubbing issues at all.
2016 M235i xDrive
Dinan Stage 4 Tune (Big turbo, exhaust, intercooler, etc)
Dinan lowering springs, bump stops, front and rear sway bars.
      02-06-2021, 12:10 AM   #12
Conntron
Conntron
Conntron's Avatar
Drives: Bmw M235i
No man I actually haven't lowered just the picture makes it seem lowered I guess! I appreciate the picture. What's your review on them ?
      02-06-2021, 01:15 PM   #13
Conntron
Conntron
Conntron's Avatar
Drives: Bmw M235i
Would you recommend them ?
      02-10-2021, 03:30 PM   #14
makrop
makrop's Avatar
I swear the M240i sits a lot higher than the M235i. Our cars look to be the same ride height and mine is on the springs. That picture was taken about 30 mins after they were installed though. I think they have settled in a bit lower. It made a huge improvement in my mind vs my stock height, but my fender gap was way bigger than what yours looks like.
      02-12-2021, 12:29 PM   #15
TheSniper
Oh yeah, the car sits and looks so much better.
And the suspension mods have done more for the handling and all that than I could have imagined.
