02-10-2020, 12:34 PM | #1 |
Spoiler Bandit
1650
Rep 872
LED amber front indicators
What are you guys having success in using for Amber LED turn signal bulbs. Bought some off Amazon with great reviews. Coded them out still flash regardless
02-10-2020, 02:08 PM | #2 |
Rep 345
I just put these in:
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1 Been working great but its only been 2 days lol They say they are CanBus friendly but I had already coded out the flash with Bimmercode before install. Did you code out the test for Warm and Cold and set bulb type to LED? You need to set all three codes for every bulb (left and right, etc). |
02-10-2020, 03:18 PM | #3 |
Spoiler Bandit
1650
Rep 872
Seriously??? Those are the same ones I am having issues with!
I will say this, if you leave them as bulb and not code them out to LED, they flicker less. They are super bright. I didn't like how hot they were though running as LED nor bulb type. I'd have reservation about burning my headlight housings with them. This is an issue with the Chinese brands versus say a brand name bulb And yes, I did code all three areas out for both sides. Both sides flickered too. Did you keep your lights on for awhile? I was able to see it rather easily with my headlights pointed a few feet from my garage door |
02-11-2020, 09:29 AM | #4 |
Rep 345
I coded them warm check no, cold check no, bulb type LED. Have not seen them flash.
When are they flashing for you when you start car (cold check) or while driving (warm check)? Now I'll have to test them out and pay more attention to see if mine are flashing. They are much brighter than stock both steady and while blinking. I like them brighter while blinking and at first I wished they were less bright for the parking light but since I dont have fog lights I kinda like having them super bright when I drive at dusk or in rain with just parking lights/halos on. |
02-11-2020, 11:48 AM | #5 | |
Spoiler Bandit
1650
Rep 872
02-12-2020, 09:45 AM | #6 |
Rep 345
I stopped and started the car with tails on, no flicker. My whole drive home last night, no flicker.
Is your flickering rhythmic like when the car is doing its bulb tests or is it random? If it were one bulb I might say you got a bad one or installed one wrong, but if its both? Are you sure you coded correctly? Did you have trouble installing maybe both are not in all the way? |
02-12-2020, 10:40 AM | #8 | |
Spoiler Bandit
1650
Rep 872
I am using these in my front headlight turn signals, not the tail lights. I have no issues with the LED's (different brand) that I used for the rears. Coded them out fine. Using Bimmercode and coded everything out in the front too. They flicker 100% of the time. |
02-12-2020, 07:09 PM | #9 |
Rep 345
I did LEDs all around. Front turn, rear turn, reverse, brake, emerg brake. None of them blink (so far).
I bet your coding for the front didnt work, did you try again? |
02-17-2020, 10:13 AM | #10 | |
Spoiler Bandit
1650
Rep 872
Maybe I will try a spare LED bulb that I used in the tails to see if those work... |
02-18-2020, 12:00 PM | #11 |
Rep 345
The front bulbs are size PY21W (also called BAU15S) and the rears are 1156, so they better not fit. The pins are the front bulbs are 150 degrees while the rears are 180 from each other.
