08-05-2022, 01:02 PM | #1 |
Rep 26
Drives: 2016 BMW M235i
Charge Pipe Advice
Hey everyone, I own a 2016 M235i auto that has 53k miles at the moment. It still has the oem charge pipe and I want to replace it before anything happens. This week I actually ordered the vrsf charge pipe in anticipation that it would be in stock 8/3 as the website page said, but come that day nothing happened. So I emailed them and they said it had been delayed and I might not ship it till their 8/20 shipment. So I cancelled my order because I want one quick. Now I am looking into other brands like CTS, ER(expensive), and FTP. Any recommendations or advice on these brands or any other too? Is the ER charge pipe worth the extra $$$ or will cheaper like CTS do the job fine? Thank you!
16’ M235i
08-05-2022, 04:36 PM | #3 |
Rep 1,020
Not sure why fulfillment speed is that important for something you say is purely preventative. Do you have reason to believe your current one won't last another month or two?
08-05-2022, 04:51 PM | #4 |
I like biscuits
164
Rep 250
when it goes, it goes. With no warning, and will leave you stranded. Best to get one on hand asap if he's still got stock. just do the math on the age of that already brittle plastic pipe. literal ticking time bomb of suck, that will leave you stuck on the side of the road. No one wants that.
08-05-2022, 05:04 PM | #5 |
Rep 112
I also installed the BMS charge pipe (also did the intercooler). I like both pieces and feel they are well-made. Extreme Powerhouse (x-ph.com) is a forum vendor and got things to me quickly.
Good luck. DBinOC |
08-05-2022, 05:15 PM | #6 | |
Rep 1,020
08-05-2022, 05:32 PM | #7 |
I like biscuits
164
Rep 250
It throws a hard Drivetrain malfunction code, and you would think you can limp it, but no you can't limp it home (especially if your 10+ miles out). I have experience trying, didn't make it out of the parking lot I coasted into.
08-05-2022, 05:41 PM | #8 | |
Rep 26
16’ M235i
08-10-2022, 07:46 PM | #10 |
Rep 446
I installed the ER pipe this spring. High quality and fits well.
Getting the old pipe out is the hardest part of the job. I would suggest just cutting it. It's going in the trash anyway. Once it's cut even half way in the middle, you can fold it into an L shape and it will slide right out. Just be careful cutting, as there is an AC hose and the power harness for the steering rack in the vicinity. Use a sharp utility knife. The OEM pipe is polyethylene, like a very thick milk jug. Getting the clamps oriented is a little tricky too. I had to pull the top pipe out twice before I got them in right. The best position for me was to have the clamp bolts on the bottom, with the bolt heads pointing down at a slight angle toward the driver side brake caliper. Plenty of clearance from the AC hose above the pipe, and easy access to tighten the bolts from beneath the car. |
08-11-2022, 01:54 AM | #11 |
Rep 5,262
a little trick I saw on videos online is to put some rubber friendly lube like the SilGlide used for the brake boots on the pipe and the middle fitting that allows you to easily rotate either side of the upper and lower pipes with little effort for perfect adjustment and prevents leaks, as well as on the rubber O rings against the intercooler and throttle body.... do not use oil.... make sure is lube rubber friendly
08-20-2022, 05:15 PM | #13 |
Rep 191,163
We offer FTP, MAD, BMS, AA, and CTS. Any of these options will work without any issues.
Evolution Racewerks is the best option if you do not mind paying more for a US-made product. It also got the best finish quality.
08-20-2022, 05:44 PM | #14 |
Rep 26
I ended up ordering the ER charge pipe from you! Planning on getting it installed next week!
16’ M235i
Info@mad-us.com1969.50 |
08-20-2022, 06:40 PM | #15 |
Rep 191,163
Congrats
