11-07-2024, 10:28 AM | #45 |
Rep 89
Okay...I think I finally got the issue resolved and it was something unexpected, so I figured I'll share in case someone experiences same/similar issue.
It turns out that I have a slow leak in front passenger tire (must be very slow since I don't daily the car and it never went low enough to trigger the TPMS alert.) I probably wouldn't have noticed if it wasn't for the leftoverture recommendation on the tire psi, so thank you sir! FYI, the front passenger side tire psi dropped to 26psi (driver side front @34psi and both rears @36psi). Once I got the slow leak fixed and now that I'm able to maintain 34psi in both fronts, no more issues. Surprised how sensitive this car is to tire psi... |
11-07-2024, 10:44 AM | #46 |
Rep 65
Thanks for the update.
I'm surprised that an 8psi difference didn't trigger the TPMS. |
11-07-2024, 01:14 PM | #47 | |
Rep 708
11-07-2024, 01:26 PM | #48 |
Rep 554
11-07-2024, 04:15 PM | #49 |
Rep 65
Could be. I wouldn't check one tire cold, then go for a ride, then check a different tire warm. I would just check all the tires at the same time........but that's just me.
11-08-2024, 11:33 PM | #50 | |
Rep 384
Yes..... the car is very sensitive to even a drop of 2lbs on either tires for front or rear axles and even more if you have a staggered set-up. This becomes an issue for RWD if they are outbalanced on hard acceleration because in same time you will strongly feel loosing traction and this is not feeling good. I would say the 240i always need 4 even tires. You must always replace them as a set of 4 otherwise the car behaving is unpredictable. Just my opinion.
2019 M240i, Melbourne Red, Black Interior. 3M Tint, Premium Package, Harman Kardon, Adaptive LED Head Lights, M Performance Exhaust and Diffuser, Chrome Exhaust Tips, 719M Bi Color Wheels, Black Kidney Grille, Burger Tuning JB+.
11-09-2024, 10:37 AM | #51 | |
Rep 2,048
My staggered summer PS4s rears seem to have excellent lateral grip well past the wear bars. But noticed the straight line grip isn't what it used to be. |
11-09-2024, 10:51 PM | #52 | |
Rep 384
It works well for me and the tread wear is even on all 4. I keep them at 38F/45R. If you loose straight line grip on acceleration, your tires need to be replaced.
11-13-2024, 12:59 PM | #53 |
Rep 5,397
PSI too high in the rear. You likely have non Runflats at runflat PSI
11-13-2024, 10:09 PM | #54 |
Rep 1,123
11-13-2024, 11:00 PM | #55 | |
Rep 5,397
But on the door, I thought it was pretty high depending on tire size. So maybe up yo 40psi? Either way, it's higher than a normal tire, and higher pressures cause the tire to elongate and reduce the contact patch. Happened to me. I have 18x9 in my rear with 255/35?/18s and keep it at 34ish |
11-15-2024, 02:00 PM | #56 | |
Rep 1,123
11-15-2024, 02:08 PM | #57 | |
Rep 5,397
I put it down to 34 and all is well. |
11-15-2024, 02:21 PM | #58 | |
Rep 1,123
https://www.motortrend.com/features/...ssure-sticker/ |
11-15-2024, 02:22 PM | #59 |
Rep 89
To me, what I was happy to find was that the front PS tire was low, thus explains why the symptom felt more pronounced in left sweeping curves (there by loading up the front PS tire more). I was wrecking my brain checking and comparing left and right side components...lol
11-16-2024, 11:05 PM | #60 | |
Rep 5,397
11-16-2024, 11:23 PM | #61 |
Rep 1,123
What it literally says is "Every car comes with an NHTSA-mandated tire pressure label, usually found inside the driver's door, that lists a set of tire pressures as well as the maximum combined load for passengers and cargo. NHTSA will simply tell you to run those max-load cold tire pressures".
11-17-2024, 12:30 PM | #62 | |
Rep 5,397
"Some car companies list multiple recommended inflation pressure combinations based upon the load the vehicle is carrying, speed, tire size, and what type of tire is fitted—winter, summer, etc." |
11-18-2024, 04:46 PM | #63 | |
Rep 1,123
11-18-2024, 10:37 PM | #65 | |
Rep 384
Why the OEM PSS summer tires were branded BMW? Where they made of a different compound of the Michelin regular tires that we get on the aftermarket? This may explain why they were labeled to run at very high pressure like mine at 38/45.
11-19-2024, 01:54 PM | #66 |
Rep 1,123
