2Addicts | BMW 2-Series forum BMW 2 Series (F22) Forum BMW 2 Series Coupe and Cabriolet (F22/F23) General Forum Rear end feels like it's sliding on ice
      09-30-2024, 11:54 AM   #1
NKOTB2015
Drives: Lexus LS460, Toyota Sequoia, B
Started noticing about a month ago that when taking fast sweeping curves, my rear end feels like it's driving on ice...like it's going to slide out. It hasn't actually slid out or cause me to lose control yet, but it feels alarming to the point where i'm forced to slow way down.
Checked tire condition and inflation and both are fine so I'm guessing something is going on in the suspension...if anyone have a suggestion on what to look for, that will be greatly appreciated.
Thank you,
      09-30-2024, 03:41 PM   #2
BringBackButtons
Smart Enough to Scan for Codes First
BringBackButtons's Avatar
62
Drives: F23 M235i 6MT
How old are the tires?
      09-30-2024, 03:47 PM   #3
NKOTB2015
3yrs. I'm leaning that it's not age of the tires since the problem started about a month ago...i don't think the age of the tires would cause this type of problem over night? If it got progressively worse, then maybe.
      09-30-2024, 03:54 PM   #4
BringBackButtons
62
Just trying to gather data as it wasnt stated. Start simple is my avenue.
Vague or uncontrollable rear end feeling could be your sway bar or sway bar links? Thats my first "easy" check to start with.
Beyond that, rear toe links or differential is what id check after that. Good luck, im not mechanically inclined to help you further than that on this platform yet as i dont have any experience yet replacing those. Youtube may be your friend, or pay a mechanic a case of beer to just do a quick check...make sure he checks the car before drinking said case of beer 🍺 🤔 😅
      09-30-2024, 04:26 PM   #5
Kernel Kurtz
Kernel Kurtz's Avatar
388
Drives: 2020 M240i xDrive
If the overall balance of the car has changed from understeer toward oversteer be sure to consider any recent changes or out of spec elements in the front end as well.
      09-30-2024, 05:53 PM   #6
2ndRat
Drives: '19 230ix, '15 GTI, '25 Mini S
Rear end feels like its sliding on ice
Also consider checking wheel alignment in rear. I'm relatively new to BMWs, but had an issue years back with a Audi quattro - tire tech failed to tighten the locks on rear toe adjustment after an alignment. The car behaved a lot like you describe.
      09-30-2024, 06:51 PM   #7
John in VA
Drives: 2015 228i M Sport
Make sure the rear trailing arm bushings are in good shape.
      09-30-2024, 06:59 PM   #8
leftoverture
leftoverture's Avatar
Drives: 2016 BMW 228i
What tire pressures are you running front & rear? These things are very sensitive to pressure and a drop of a couple pounds can be noticeable, so let's stay on tire pressure until we have your data.
      09-30-2024, 09:24 PM   #9
Nickies
Drives: 2019 BMW M240I
You don't tell which model you have.
2019 M240i, Melbourne Red, Black Interior. 3M Tint, Premium Package, Harman Kardon, Adaptive LED Head Lights, M Performance Exhaust and Diffuser, Chrome Exhaust Tips, 719M Bi Color Wheels, Black Kidney Grille, Burger Tuning JB+.
      09-30-2024, 11:10 PM   #10
zoro2001
zoro2001's Avatar
Drives: 2014 M235i
2014 BMW 235i  [0.00]
He's got a 235i conv.
      10-01-2024, 07:36 AM   #11
NKOTB2015
Thanks for the feedback so far guys. Just to add, I'm running square set up runflats...34psi all around. I'm still not convinced its due to tires (due to the sudden onset of the symtoms...I would think tire issue would come on more progressively?) but obviously I'm no expert, which is why I'm asking here lol.
      10-01-2024, 07:38 AM   #12
NKOTB2015
Thank you for your feedback. I'm planning to take the wheels off and check the suspension this weekend.
      10-01-2024, 07:41 AM   #13
NKOTB2015
It's not so much shifting of the overall balance...it literally feels like the back end is on ice when I'm driving through a curve...get the same butterfly in my stomach...you know the feeling when you feel like you're about to lose traction (and control) driving in icy conditions in the winter? but it's isolated to only back end of the car.
      10-01-2024, 07:42 AM   #14
NKOTB2015
Will do after I check out recommended suspension components. Thx.
      10-01-2024, 07:45 AM   #15
NKOTB2015
Thank you for your feedback. Is this a visual check? Just wondering what the best method is for checking the bushings...unless they're obviously rotted out or something...what should I look for and how to check? Thanks again.
      10-01-2024, 11:08 AM   #16
freakystyly
Drives: F22 B58 6MT
Nothing on the road like gravel, oil, soap?
Tire tread still deep enough?
Wet or dry roads?
Does it only happen when applying gas or does it happen when coasting too? Only when cornering or does it seem like your spinning more on acceleration too?
It sounds like you're driving with traction control off since it would be freaking out at the slightest slip, so it likely wouldn't be related to that...
      10-01-2024, 12:33 PM   #17
NKOTB2015
Wet or dry roads?
No, sir. clean, dry roads.
I want to say both under power and coasting...I enter the curve under moderate power and have to lift off due to the "rears on ice" feeling so I don't end up spinning out (hasn't happened yet) but still get that slick feeling in the back even when coasting through the curve.
Traction control on.
      10-01-2024, 12:53 PM   #18
zoro2001
zoro2001's Avatar
Drives: 2014 M235i
Try going to a parking lot and see if the back end actually let's go.
      10-01-2024, 01:15 PM   #19
freakystyly
Drives: F22 B58 6MT
Any curb hitting or road debris?
Sounding like an alignment issue as mentioned in post 5. If something changed quickly and not gradual.
      10-01-2024, 02:07 PM   #20
NKOTB2015
I'm hesitant to try this out...not many parking lots big enough and empty enough...and I don't want to drive that fast through a parking lot, regardless of there are ppl around or not.
      10-01-2024, 02:08 PM   #21
NKOTB2015
Hmmm...no...deft no curb hitting. I do remember hitting a pothole...but can't remember exactly whether that was before or after this issue.
      10-01-2024, 09:46 PM   #22
leftoverture
Try 32 psi front and 36 in back. When I felt my rear was loose that's what I went with and it made a huge difference.
Search this Thread:
Copyright ©2000 - 2025, vBulletin Solutions Inc.
