02-20-2016, 11:37 PM | #1 |
Rep 40
Drives: Alpine white, Coral red M235i
Pure stage2 T-upgrade
After a great amount of time spent reading and going through this forum and N54tech I still didn't find a clear path for my goal.
Currently the car has FMIC, CP, DP and (Jb4 EWG OBDII) and I am opting for a turbo upgrade. From what I gathered PS2 is the better option I think but it needs supporting mods to make the car reliable and can be used as a daily driver which is my plan to keep it this way. In terms of fueling unfortunately I'm bounded to use 93 only where I come from. What I'm looking for is to get the maximum out of this T-upgrade using only 93 Oct. Any suggestions fellow 2Addicts?? |
02-21-2016, 04:56 AM | #2 |
Rep 84
Drives: '14 BMW 335i
If you live currently in KSA then you are limited to 95 RON not 93 AKI [95 RON =~= 91 AKI], the fuel in KSA is really shitty it's equivalent to around 89/89.5 AKI. Our fuel in Bahrain is slightly better but still shit.
Better off to invest in methanol injection system before going with the Turbo upgrade. With your current mods and 100% meth you will make around 380 WHP++ on a dynojet. If you went with the turbo stage 2 upgrade only you might make around 380-400 WHP with your fuel.
'14 F30 335i N55 EWG - Speedtech Stage 3 EFR 8374 - BM3 Custom Tune - xHP Flash - BMS Meth kit - Dorch Stage 2 HPFP - ER FMIC & CP
02-21-2016, 08:39 AM | #3 |
Rep 50
Drives: 2015 m235i with FBO
It seems to me that the methanol injection would be a better option in terms of reliability and going easy on the engine as well due to the reduced chance of knock and decreased intake temps.
02-21-2016, 12:07 PM | #4 | |
Rep 895
As for additional mods, be sure to get the upgraded diverter valve and inlet pipe from pure.
2019 SG M5C
02-21-2016, 11:37 PM | #5 | |
Rep 40
Thanks kfardan for the good info. what about going in the direction of TBI will it make it better in terms fueling and reliability or should I just focus on the getting meth injection then opt for the turbo?? |
02-21-2016, 11:50 PM | #6 | |
Rep 40
02-22-2016, 12:04 AM | #7 |
Rep 40
Pure Turbo guy said you don't need to run higher octane fuel to get a reliable power bump because of the reduced exhaust back pressure.
Here is quote of what he said: "It does make sense. The larger turbine wheel in the Stage 2 allows the engine to breathe much better (imagine the stock turbine is like breathing through a straw). This leads to lower exhaust back pressure, increased overall efficiency, and therefore less pre-ignition. So you can run more boost safely without needing so much octane to band-aid the situation. Hope that makes some sense." what do you think?? |
