Frozen paint owners, read before you decide to upgrade spoiler |
04-16-2024, 08:11 PM | #1 |
Rep 594
Drives: 2018 M5 / 2011 X5 35d
Got a 2018 M5 first edition with the frozen dark red paint.. I decided to upgrade to a high kick CF spoiler. After removing the old spoiler, cleaning the 3M double sided sticky mess I was left with some pretty pronounced mark on the paint where the old spoiler was.
How do I get rid of them? Keep in mind that this is frozen paint and technically I can’t use any sort of compound, polish, or wax. Any help will be appreciated. Last edited by M5_1of400; 04-18-2024 at 02:16 PM.. |
04-16-2024, 09:51 PM | #4 |
18978
Rep 11,127
Drives: M4 CS. Former G82, x2 F82, F80
Us frozen paint owners always seem to learn these things AFTER we buy the cars hah!
Our paint still looks the best though. |
04-18-2024, 09:33 AM | #6 |
You got my money?
3620
Rep 4,849
Drives: Ice Cream Truck
Ouch... I would be crushed.
Did you use a 3M rubber wheel to remove the double sided tape? Because if you did, that might be rubber from the the wheel that if lucky; maybe you can wipe it off with some rubbing alcohol? But that kind of does look like its already burned paint. Oh that hurts to see.
2022 G80 M3 Competition X /// 2025 X5 40i X
04-18-2024, 09:41 AM | #7 | |
Rep 594
My only options are: - put the old spoiler back (boring) - Buy a different spoiler that covers the marks (I don’t like the spoilers that kick almost at a 70 degree angle) - say fuck it and repaint the trunk lid (don’t even know how much it will cost me) So. If you have a frozen colored car let this be a warning if you are trying to upgrade your spoiler. I wish I would have done more research to learn this before I decided to upgrade. |
NickyC18977.50 |
04-18-2024, 09:50 AM | #8 | |
You got my money?
3620
Rep 4,849
Id probably cut your looses and revert back to stock to hide that. Not to sound negative, but matching older matte paint would be a challenge in my opinion. At least reverting back to stock hides it!
NickyC18977.50 |
04-18-2024, 12:11 PM | #9 | |
Rep 594
You are absolutely correct, just got an estimate from a reputable body shop, they won’t touch it unless they also redo the side panels to blend it. Minimum a $3k job. |
04-18-2024, 02:51 PM | #10 |
Rep 594
Ok, I'm going to try this.
https://www.rwcarbon.com/bmw-g30-f90...k-spoiler.html Looks like this spoiler will sit on top of the affected area covering most of it. |
NickyC18977.50 |
04-18-2024, 06:03 PM | #11 | |
18978
Rep 11,127
04-19-2024, 07:18 AM | #12 |
The Seeker
14954
Rep 3,685
BMW frozen paint is the same as any other paint in that the last step is a clear-coat, it's just more matte. I would say that a reputable bodyshop could scuff that area, removing the issues, without breaking through the color, and then just matte-clear it. Shouldn't be an issue at all. The hardest part is matching the matte-clear.
04-19-2024, 07:51 AM | #13 |
Rep 2,474
Before repainting hit it with a mini buffer like rupes ibrid nano and meguiars 205 polish and work your way up in the abrasives line if necessary. You can even use a larger big foot; just tape off surrounding areas. You may be able to buff out what appears to be calcium in the paint. Then put the m5cs or m5comp rear deck lip on to cover the polished area. That should cover most of it. Just an idea before spending 3k.
04-19-2024, 08:47 AM | #14 | |
Rep 594
04-19-2024, 08:51 AM | #15 | |
Rep 594
Yesterday I got the RWCarbon CS spoiler that looks like it would cover all of it, I rather cover it and forget about it. |
clutchdj2057.00 Westside Guy6778.50 |
04-19-2024, 08:54 AM | #16 | |
Rep 69
04-19-2024, 10:50 AM | #17 |
The Seeker
14954
Rep 3,685
If they would rather feather 3 panels (blend) with color they don't have to use instead of just cleaning and clearing it's a cash grab, regardless of their rep. I've been doing bodywork since 1989, and I can tell you without a doubt that blending is only needed when the color is broken through.
04-19-2024, 12:26 PM | #18 | |
Rep 69
04-19-2024, 12:50 PM | #19 | |
Rep 594
04-19-2024, 12:57 PM | #20 | |
The Seeker
14954
Rep 3,685
I don't do bodywork full time anymore, but I know it quite well, and disagree with your statement. You literally have no idea how deep the clear is on that trunk, or how deep the issue is, so it's impossible for you to say, you're just speculating. Lastly, even if the clear was broken through (unlikely), as long as the paint doesn't have flake in it you can still clear over it, as long as you don't break through. As far as I'm aware, the frozen paint that BMW uses has no flake in it, but it's possible that rubbing it directly could cause the spot to be visible, so you'd have to spot-it anyway. Still better than blending 3 panels... |
04-19-2024, 01:19 PM | #21 | |
Rep 69
04-19-2024, 01:21 PM | #22 | |
Rep 69
