06-09-2021, 12:20 PM | #1 |
Rep 196
6MT sandy/ feels like shaving metal, shifter bushings?
Noticed 2000 miles (55k) ago that occasionally the shifter feels sandy like there is metal on metal contact while moving the shifter assembly anywhere, like the shift linkage is be abraded or creaking like old knees. This occurs in all the gears, in and out of gates, around in the gates, reverse etc. It is especially apparent on the left of the "box" if you move against that boundary either into the first two gears or inside either of them.
Seems to come on when I'm in city like traffic and not moving as much, as temps/speeds rise. CDV delete already done a while ago, everything to do with clutch is working perfectly. Trans fluid swapped to Redline DCTF 1000 miles ago. Better cold shifting and overall much nicer but still comes and goes. Shifter bushings, syncros, overheating trans, etc?? Anybody else have this happen?
14' Alpine White M235i 6MT, BM3 Stg2+, VRSF DP-CP-FMIC, Dinan Muffler, GFB DV+, 3.5 bar MAP, Dorch Stg1 HPFP, NGK 97506, BM3 Flexfuel Kit, CDV delete, KW V3, EDC delete, Powerflex Camber LCA bushings, VMR 801 18x8.5/9.5 et45, Conti Extremecontact 235/265
Next step: M2 Competition or Manual Supra MKV build Summer 2022 |
06-09-2021, 12:24 PM | #2 |
Rep 196
I will note it shifts perfectly without any problems, I don't think it's a syncro issue, and it doesn't make any sounds. Just feels wrong
06-09-2021, 01:02 PM | #3 |
Rep 243
Get under your car and make sure all these components are in good order. Something may be worn out.
https://parts.bmwinmelbourne.com/a/B...n/25_0534.html
'15 235i - Moddedededed
06-16-2021, 06:16 PM | #4 | |
Rep 266
