06-04-2021, 10:40 AM | #1 |
Rep 68
Tension Strut Bushing upgrade; is alignment needed?
I'm replacing my tension struts with OEM F22 tension struts (not upgrading to the M4 ones).
Before the swap, I am going to replace the stock bushings in the new tension struts with Millway monoball bushings (link below). Question: Will I need an alignment after adding the monoball tension strut bushings? I'm aware alignment is essential when swapping the LCAs with M ones, and I've done that already. However, not clear if alignment is again required when swapping OEM tension strut bushings. Thank you! Bushing part link: https://www.millway.se/front-control...w-f20-f30.html |
06-04-2021, 04:50 PM | #2 |
Rep 3,539
Drives: 328d Wagon, M2 Comp, i4 eD35
It's not critical, but it's a good idea. The stock bushing has the bolt hole offset from the center of the bushing a bit, while all the monoballs have it right in the center so switching will give you a bit more caster than before.
-328d Wagon Build Log (with helpful reference links)
-My YouTube Channel for some of the best DIYs and in depth information Please don't PM me for suspension recommendations unless interested in paid private consultations. |
sauceonside31.00 |
06-05-2021, 04:51 PM | #3 | |
Supreme Allied Commander
3843
Rep 54,367
Drives: F80 M3
