05-25-2021, 10:27 PM | #1 |
Rep 185
Drives: BMW M240I XDRIVE
Brake shuddering when hot
I recently replaced my brake rotors and pads, I went through the break in procedure n seemed ok. When I took the car up to a high rate of speed and went to brake I noticed that the brakes shutter and it is almost like warped rotors but seems to only be noticeable when the brakes get hotter. Any ideas?
05-25-2021, 10:51 PM | #2 | |
Rep 5,262
If you didn't clean the rotors well with brake cleaner maybe you had still oily residue from shipping and that overheats |
05-26-2021, 01:44 PM | #4 |
Rep 3,496
FWIW, the front and rear M-Sport calipers are fixed.
05-26-2021, 01:51 PM | #5 |
Rep 5,577
05-26-2021, 09:46 PM | #6 |
Rep 185
I got up to high speeds to try get a feel for what is going on. Once again when cold it feels fine. After a second they get hot n I loose brake power and it starts to shudder.
05-26-2021, 10:15 PM | #7 |
Rep 185
05-26-2021, 11:27 PM | #9 |
Rep 185
05-27-2021, 12:05 AM | #10 |
3626
Rep 3,592
First the easy confirmation of a seized/sticking caliper, carefully put a hand near the centre of the wheel after driving the car and compare with the heat coming from the wheel on the same axle on the other side. You may be able to quickly touch the end of the wheel bolts, but there is a risk of burning your fingers if you are not careful. Any difference in the heat from side to side on that axle is a good sign of a stuck caliper.
A rebuild (if the pistons and bores are in good shape) of the caliper or replacement is needed. If you have done it before you can replace or rebuild yourself, if not a BMW specialist is a good bet to do the work. |
ahakim2421.00 |
05-27-2021, 11:44 AM | #11 | |
Rep 185
05-27-2021, 12:18 PM | #12 |
3626
Rep 3,592
If that is the case, going by the uneven heating in your photo, they may have been broken in incorrectly due to the lack of an even pad deposit, I would follow the pad and rotor manufacturer break-in procedure, as they are not all the same. The other issue may be variable rotor quality, if they are not a BMW or OEM supplier to BMW part.
ahakim2421.00 |
05-27-2021, 12:27 PM | #13 | |
Rep 185
05-27-2021, 12:31 PM | #14 |
Rep 5,577
If u did the work yourself.
Disassemble, and reassemble carefully using proper or as close to proper torque specs as possible. Clean the hub surface with scotch-brite and use/get new caliper mounting bolts. Inspect all surfaces, pads, rotors, hub and confirm anti rattle or mounting spring is installed correctly. Also do a break flush and start by siphoning old fluid out of master cylinder reservoir. I do not use brake cleaner on rotors. If your rotors come encased in wax eradicate as the instructions state. Also, I don’t recall on my BMW but caliper pistons can be retracted two ways 1) by rotating or 2) being pressed straight in. So be sure the piston rubber is seated properly. Then retest brake performance on the street. Always do the easy stuff first. |
ahakim2421.00 |
05-27-2021, 12:43 PM | #15 | |
Rep 185
05-27-2021, 01:34 PM | #16 | |
3626
Rep 3,592
ahakim2421.00 |
05-27-2021, 06:27 PM | #17 |
Rep 3,496
Which Amazon vendor sold you the pads?
I wouldn't buy Brembo components from Amazon unless the vendor could be confirmed to be an authorized Brembo supplier.
05-27-2021, 10:26 PM | #18 |
Rep 185
06-02-2021, 09:57 AM | #21 |
Rep 185
06-02-2021, 12:00 PM | #22 |
Rep 345
Most of the time when you have pads on a rotor that wasnt before (new pads, new rotors, or hopefully both new) on the first drive you want to overheat the shit out of them WITHOUT STOPPING THE CAR then "cool" them by not touching the brakes while moving for a long period. Basically you want them very hot so they mate together, heat cycle together, and then cool down slowly. If you come to a stop while they're hot, the pads start depositing material on that one spot on the rotor, and the rotor is increasing in heat where the pad it touching it while decreasing in heat everywhere else. Not good.
If you do get them hot as hell and then slowly cool them on the first drive, they are now both heat cycled and "bedded" or "mated" to each other. Supposedly you will get better braking and they last long and less chance of making hot spots or warping in the future. When I do brakes, what I do is drive gently to the nearest highway and hopefully the onramp has no traffic light. You drive like an ass near the entrance ramp with 40 to 1mph stops, then 60 to 1mpg, then 90 to 1mph at this point you should feel the brakes losing bite by overheating and maybe even smell them if they are aggressive pads. I said 1mpg instead of 0mph because you DONT want to stop while the brakes are overheated. Then you get on the highway and set the cruise control to a speed less then traffic so you never have to touch the brakes and drive 20-30 min so your overheating brakes are now spinning in cool 65mph air and cooling down slowly. If you get caught at a light or stop sign, just roll forwards and backwards as much as you can you really dont want that blazing hot pad to stop on the rotor. When you say "I didnt" did you overheat them and then park the car? No es bueno. |
