05-10-2021, 03:27 PM | #1 |
Rep 176
Parking brake after MP brake install
I switch out the msport brakes to mperformance red ones on my m235 xdrive. I also switched to mperformance discs and pads.
Even after adjusting the handbrake as far as it will possibly go, it's still not engaging, almost like it is not going to lock onto the wheels. Do I need to change something else for this to work? Thanks in advance. |
05-10-2021, 04:23 PM | #2 |
3612
Rep 3,579
After switching the rear discs, the parking brake shoe pawl in the "hat" of the rear discs will need to be adjusted through one of the bolt holes. Often when the old discs are removed, the adjusting pawl has to be backed off to allow the old disc to be removed without the shoes catching on a ridge of rust and has to be readjusted to the new disc. The pawl is normally adjusted to about 7 notches from locking up the disc when the parking brake is off.
WolfGTI716.00 Raymondo123467.50 |
05-10-2021, 09:12 PM | #4 |
3612
Rep 3,579
Typically you have to back off the adjuster to remove the old disc if a rust band has built up on the inner edge of the braking surface where the shoes don’t touch, the rust expands the original surface so will require the shoes to be retracted more than the size of a new disc. The key is to adjust to the correct spec after fitting the new disc.
Raymondo123467.50 |
05-10-2021, 09:18 PM | #5 | |
Rep 5,262
last time i did mine I backed it off a few clicks until the old disc came off and then made sure when i put the new disc that there was just a little bit of resistance when moving the disc by hand and seems to have worked just fine... |
05-10-2021, 09:50 PM | #6 | |
3612
Rep 3,579
Raymondo123467.50 overcoil3073.50 |
05-13-2021, 02:20 PM | #8 |
Rep 176
So I tried, but even when adjusted to the most closed position, it still isn't enough to get it anywhere near touching.
Is it a different part for xdrive? I can't work it out. |
05-13-2021, 03:35 PM | #9 | |
3612
Rep 3,579
You probably have installed either 34206797607 for plain rotors or 34206797600 for cross drilled rotors (or aftermarket equivalent), but need 34206797605 for plain rotors or 34206797598 for cross drilled rotors. The alternative is to install the larger parking brake assembly off an F30 340i or other vehicle that uses the larger hat. Your original M235xi rear rotors should be the correct 345x24 (34206797605) ones, though. Last edited by aerobod; 05-13-2021 at 03:56 PM.. |
Raymondo123467.50 |
