Are Tunes Removed Detectable Via BMW Service (JB4/BMS/RaceChip) |
02-25-2016, 08:03 AM | #3 |
Rep 596
Any tune is detectable if they look hard enough. The car logs what boost its hitting etc. A 10 psi over stock target will look a little suspicious. Routine servicing won't uncover it, but investigations into engine warranty work probably would.
02-25-2016, 08:41 AM | #4 | |
Rep 282
Agree but I've seen no confirmation for BMW, it is highly likely
A good forensic software engineer can detect any modification to his software. My impression is that Audi began to get very serious about detecting tunes circa 2005 and installed features that detected firmware modifications in their new models around that time. I expect that all manufacturers have that ability now. Bottom line, unless the tuner gives you a guarantee in writing that it is "undetectable" and guarantees to reimburse you for any repair denied due to a tune, I'd assume you are driving a vehicle that is no longer under warranty. |
02-25-2016, 12:21 PM | #6 |
Rep 1,931
Quick answer is yes.
If your service manager is a cool guy, he will most likely overlook the mods and just get his job done. If something goes wrong with your car, the first thing they will blame will be your mods. This may allow them to NOT cover any of the parts covered under a factory warranty because your mods destroyed them. Its a very slippery slope. Mod at your own risk.
www.nybmwcca.org
02-25-2016, 01:57 PM | #7 |
Rep 191,471
Very grey area
Maybe they can , maybe they cannot. I have never seen a proof where they caught a piggy after it was removed. 1 thing is for sure, your techs do not check for traces of a piggy and it has been suggested before that the techs might not have the access or tools to find a piggy only engineers. Everything we read / see (including my post) is speculation. Fact is remove your tune before your dealership visit and you will be fine. Note: Piggy work by tricking the system into thinking that it is running stock boost. So after it has been removed, if you do a boost scan it will show stock boost because thats what the ECU thinks it was running. Of course some other parameters will change with the extra boost but they might not indicate with 100% certainty that there was a tune. It could be other things.
https://x-ph.com/sale/ Phone number 702-494-9435 Last edited by mike@x-ph.com; 02-25-2016 at 03:07 PM.. |
02-25-2016, 02:58 PM | #8 | |
Rep 555
Dealer typically wont be able to, but BMW themselves can.
02-25-2016, 03:01 PM | #9 | |
Rep 191,471
Car was fully bolt on
02-25-2016, 03:03 PM | #10 |
Rep 555
He might have been lucky, but they BMW can detect it if they really look.
02-25-2016, 10:37 PM | #12 |
Rep 1,071
02-25-2016, 10:41 PM | #13 | |
Rep 191,471
Thousands do it |
02-25-2016, 10:50 PM | #14 |
Rep 1,071
02-25-2016, 10:56 PM | #15 | |
Rep 191,471
the .0000001 chance that you have a defective engine and it breaks is the case we are discussing Comparing the number of tuned cars under warranty vs the odds of something serious that breaks (couple reported over the 10 year span), i say there is nothing to worry about
02-25-2016, 11:06 PM | #16 | |
Rep 1,071
They're out there and you really really don't want it to be you. |
02-25-2016, 11:07 PM | #17 | |
Rep 191,471
but that doesnt stop you from using a condom does it?
02-25-2016, 11:14 PM | #18 |
Rep 1,071
02-25-2016, 11:15 PM | #19 |
Rep 191,471
LOL
02-26-2016, 01:21 AM | #20 |
Rep 957
As an engineer I am a bit amazed that people feel the manufacture should cover the cost of repairs to something you modified out of the design permamiters. That's not even touching the ethical issues.
If you want to mod your car, than be prepared to pay for what is no longer under warranty. It may not be the modifications fault, however there is no way to tell, so the onus falls on the modifier. Full disclosure, my car is fbo with meth injection. As to the ops question, the data logs accessible from the dme with a piggyback are indeed easy to spot a tune was installed. Mostly by the large spikes in fueling and timing. When you have a larger failure, (say an engine) the factory wants to get involved to figure out what happened mostly to prevent future issues. At a minimal it goes to a regional rep for approval. Last edited by Pparana; 02-26-2016 at 01:29 AM.. |
02-26-2016, 01:28 AM | #21 | |
Rep 191,471
More often than not they are regular maintenance stuff or caused by defective parts. I had to replace turbos on my car when it was fully stock . If this happened while my car was tuned, techs would have probably blamed the tune when the problem was with bad turbos If someone runs their car with maps too aggressive for their mods or with lower grade fuel, they should be responsible for the repairs |
02-26-2016, 01:36 AM | #22 | |
Rep 957
That is the cost of tuning the car, you loose the warranty, tune related or not. Pros and cons. To me I went jb4, much cheaper than Dinan sans warranty, but the mild additional stress to the engine seems unlikely and has shown unlikely with the millions of miles driven on the tune to cause much if any wear. |
