12-18-2022, 04:37 PM | #2 |
3615
Rep 3,585
It depends on whether the factory coolant is green or blue, supposedly they switched in January 2018 to the current green formula. You can use green in cars that are older and originally used blue, but not the other way around.
That container of "blue" (82-14-1-467-704) should be concentrated, normally requiring 50/50 mix with distilled water. |
overcoil3073.50 |
12-18-2022, 07:57 PM | #3 |
Rep 536
12-18-2022, 09:14 PM | #4 |
Rep 1,014
I've seen this info as well, but only second hand.
https://www.bimmerworld.com/Fluids/B...allon-Jug.html |
12-18-2022, 10:26 PM | #5 | |
3615
Rep 3,585
12-19-2022, 08:31 AM | #6 |
Rep 1,264
Ok, I figured it out. I had the coolants (engine and intercooler) changed last summer by the dealer. I provided the distilled water. I check the work order and the tech did use the older coolant: 82 14 1467 704. The car was built in August of 2017.
aerobod3615.00 |
