2Addicts | BMW 2-Series forum BMW 2 Series (F22) Forum BMW 2 Series Coupe and Cabriolet (F22/F23) General Forum traction control
      01-25-2023, 07:59 AM   #1
MAMSport
MAMSport's Avatar
87
Drives: '13 128i M-Sport coupe
traction control
On 2016 M235i, I was trying to do some car control practice (snowy parking lot), sliding the rear around a 'skidpad'. I had some trouble doing this, with the stability control seemingly limiting wheelspin in 'comfort' and 'sport' settings. Do I need to be a bit more aggressive in these settings, or do I need to select 'sport +' instead?
I have no trouble doing this in the 128i with a WaveTrac although without a single press of the traction button, there can be throttle reduction/intervention.
E9x M3 front & rear suspension arms; BMW Performance brakes upgraded to drilled rotors in rear; BMW performance shifter; BMW Performance Exhaust; Wave Trac LSD with modified 'nannies'; BMW Euro Intake box; BMW Aluminum Strut Tower bar; ECS front and rear sway bars; 3 stage intake with BPC software; BMW style 78, 17 x 8" wheels with Bridgestone RE 980AS 225/45-17 tires; Koni Special Active struts/shocks, E9x M3 RTABs.
      01-25-2023, 08:02 AM   #2
freakystyly
Drives: F22 B58 6MT
Sport+ allows a small amount of spin before pulling power and braking wheels. DTC single press allows for a bit more slip but still brakes your wheels. You will need to hold the DTC button for 3 seconds to allow for full slip.
Basically the same as the 1 series, ignore the sport/comfort BS for what you want to do here.
Beware curbs and light poles, and any local trespassing laws.
      01-25-2023, 08:15 AM   #3
MAMSport
MAMSport's Avatar
87
Yes, always cautious. But, as the M235i is new to me, where is the DTC button? Is it embedded in the i-drive (I couldn't find it there, but that is new to me)?
      01-25-2023, 08:25 AM   #4
freakystyly
Drives: F22 B58 6MT
Just above the sport/comfort switch by your shift knob. I think it was an icon of a car with skid marks.
      01-25-2023, 11:14 AM   #5
MAMSport
MAMSport's Avatar
87
Ah, I'll look for it next time, if I decide to buy the car. I've taken it out for a short (standard) test on a rainy evening, then had the opportunity to look at it on a lift before a drive on snowy roads (read: low friction). The car is good, but I think I like my 128i better (see my mods list).
Is this the button just forward (closer to the dashboard) of the switch for changing the Adaptive Suspension setting?
      01-25-2023, 11:44 AM   #6
freakystyly
Drives: F22 B58 6MT
see pics (disregard the ad)
https://f30.bimmerpost.com/forums/sh....php?t=1415109
I came from a similarly modded e90 330i. The 2 series drives more numb especially in stock form.. the biggest down side would be the electronic steering rack. Of course suspension can be modded as you choose, but the rack isn't really an option.
      01-25-2023, 12:01 PM   #7
MAMSport
MAMSport's Avatar
87
Thank you very much for the image and confirming. Tough decision. I think I have a 'knowing' buyer for my car. Trade value nowhere near what the car is worth to someone who understands, which certainly is not 'everyone'!
      01-25-2023, 02:28 PM   #8
dradernh
dradernh's Avatar
4393
Drives: 2017 M240i
If needed, these are the instructions from the 2017 M240i manual. I'm guessing they're the same for the M235i.
      01-25-2023, 04:48 PM   #9
Kernel Kurtz
Kernel Kurtz's Avatar
345
Drives: 2020 M240i xDrive
This is one of the handful of things that really disappoints me about this car. Can't have Traction mode (DSC off, DTC on) at the same time as Sport mode. Traction mode sets the chassis and drivetrain to Comfort settings so softer suspension and steering. It is kind of lame really.
      01-25-2023, 05:01 PM   #10
Resoelg
Resoelg's Avatar
Drives: 2024 M2 ZV-Blue
24 G87  [10.00]
The nannies are annoying but serve a purpose...I guess. We can have fun with these cars, just not TOO much fun.
      01-25-2023, 05:52 PM   #11
dradernh
dradernh's Avatar
4393
Drives: 2017 M240i
Under some very specific circumstances, the nannies saved me bigly early one morning on a local interstate highway. During street driving, I'll never complain about them being in effect on a car with so much torque at low RPMs.
They're also handy when it's 30 degrees out, dry, and I'm running my winter tires (read: Michelin Pilot Sport A/S 3+) while turning the wheel with more than a little throttle input. This car's nannies have shown me that I need to be more judicious with the throttle that I've had to be with every other street car I've owned.
Turn DSC OFF on and you can have all the fun you want, especially if you've installed an LSD. Significant negative camber helps, too.
Resoelg244.00
      01-25-2023, 10:40 PM   #12
MAMSport
MAMSport's Avatar
87
Interesting. I didn't realize that changing the DTC status would also change Adaptive Suspension back to Comfort settings. Thanks, no thanks.
      01-26-2023, 07:46 AM   #13
dradernh
dradernh's Avatar
4393
Drives: 2017 M240i
Resoelg244.00
      01-26-2023, 09:53 AM   #14
WolfGTI
WolfGTI's Avatar
2002 MINI Cooper S  [0.00]
2015 BMW X1  [0.00]
My coilovers permanently solved that issue.
Rogue Engineering SSK & transmission mounts, WaveTrac LSD.
Ohlins R&T coilovers, Turner monoball thrust arms, F87 LCAs, GC camber plates, Superpro subframe bushings, Megan Racing adj. RCAs, delrin differential bushings. Stoptech BBK 6 piston (f) 4 piston (r).
dradernh4392.50
      01-26-2023, 12:08 PM   #15
XutvJet
"Sport" mode has three settings. You can select Chassis, Drivetrain, or "Chassis/Drivetrain". "Chassis" is stiff shocks, stiff steering, the slower/linear Comfort throttle, and all nannies on. "Drivetrain" is the Sport throttle and soft shocks, soft steering, and all nannies on. "Chassis/Drivetrain" is the stiff shocks, stiff steering, and Sport throttle and all nannies on.
"Sport+" is stiff shocks, stiff steering, and Sport throttle and nannies dialed back to allow for some spin and slide.
"Traction" is soft shocks, soft steering, Comfort throttle, and nannies dialed back to allow for some spin and slide.
"DSC Off" is stiff shocks, stiff steering, Comfort throttle, nannies off, and electronic LSD on.
ECO and Comfort modes are terrible. Don't know why anyone would drive this car in those setttings
IMO, if you have a mechanical LSD, Sport+ is the best mode for fun street driving and DSC Off for the track if you're a solid driver. Otherwise, stick with Sport+.
I am astounded by how much better performing and riding my M235 is with a 245/35R18 square tire setup, a mechanical LSD, Dinan springs and OEM shocks in the front, and Bilstein B6s Damptronics in the back with stock springs.
WolfGTI716.00
      01-26-2023, 12:11 PM   #16
XutvJet
A stock M235/M240 with a mechanical LSD and summer tires will be better overall handling/performing cars than your modded 128. The 2 series has a much better rear suspension than the 1 series. The M235 with the M Performance LSD was a few seconds faster on the Ring than the 1M in BMW's own testing back in 2014. Add some mods to the M235 suspension and much needed tire width up front and it becomes very apparent that BMW nuetered the car a bit to make room for the M2.
      01-26-2023, 01:08 PM   #17
Kernel Kurtz
345
Yeah, I have both Chassis and Drivetrain enabled in Sport mode. In theory Sport+ should be what I want, but it also raises the shift points considerably more than Sport. I want to be able to have a bit of fun on snow covered roads, but I don't need every shift to be at 3K while doing so. If you have a manual of course this is irrelevant. Makes me wonder if this is something I can change with some coding. Will have to investigate further.
      01-28-2023, 09:52 PM   #18
BigSteel
Drives: BMW 235i
Why don't you just put auto gearbox into manual mode ?
In case your not aware push shifter to sport/manual transmission mode then shift it once and done it won't shift for you you have a manual
      01-29-2023, 05:30 AM   #19
mecheng77
mecheng77's Avatar
Drives: 2007 328i / 2014 M235i
  [0.00]
  [0.00]
What do you need to run 245 square?
Can you use the stock rims?
      01-29-2023, 11:25 AM   #20
XutvJet
You cannot use the stock rims. You need at least a 8" wide rim and the proper offset. I'm running an 18x8 rim with a 43mm offset and it fits perfectly with no rubbing on the stock springs and for the past 2 years on Dinan springs.
mecheng771006.00
      01-29-2023, 12:55 PM   #21
Kernel Kurtz
345
Yeah, I know how it works. My last three BMWs were all manuals and I get that urge sometimes, but it is not really necessary just to kick the tail out now and then in the snow. Traction+Sport mode together would be so much better. I think Sport+ assumes you are going to shift manually which is why it holds the revs much longer.
