2Addicts | BMW 2-Series forum Classifieds Commercial Classifieds Engine / Drivetrain / Exhaust / Bolt-ons AWE Tuning: Introducing the BMW F22 M235i S-FLO Carbon Intake. Available... Now.
      07-30-2015, 10:41 AM   #1
Andrew/AWE
Andrew/AWE's Avatar
Drives: AWE M4, AWE 328
The perfect compliment to the M235i’s athletic spirit. The AWE Tuning BMW F22 M235i S-FLO Carbon Intake:
  • 63.4% increase in air filter surface area
  • Featuring the AWE Tuning S-FLO Filter
  • Easy access design allows for filter inspection, removal, and replacement without removal of entire airbox
  • No extra couplers in system means smooth flow from filter to turbo inlet
  • Fully sealed carbon fiber box and filter combination
  • Max gains of 9 hp and 15 ft-lbs of torque at the crank
  • Perfect integration with OEM inlet ducting
  • Retains stock mounting locations
  • Plug and play MAF and breather locations
  • UV stabilized resin and clear coat prevents yellowing from heat
  • Included S-FLO Filter is durable and washable
  • Featuring No Check Engine Light Guarantee
  • Perfect Fitment - Guaranteed
The carbon fiber airbox
The AWE Tuning BMW F22 M235i S-FLO Carbon Intake is a fully enclosed carbon fiber airbox made from high grade UV stabilized 2x2 twill carbon fiber to reduce yellowing from under hood heat. This airbox mounts securely in the stock location and mates up to the factory air inlet pipes, perfectly. It boasts simple access for filter inspection and helps to deliver as much power as it does good looks.
The AWE Tuning S-FLO Filter
The included AWE Tuning S-FLO Filter is specifically designed to maximize airflow in the AWE Tuning S-FLO Carbon Intake. This increased flow unlocks impressive max gains of 9 hp and 15 ft-lbs of torque at the crank.
The carbon fiber airbox and S-FLO Filter combination makes for an easily serviceable air filter without removing the airbox. The combo produces a more aggressive intake note than stock, with a distinctive turbo spool sound, all while keeping your car operating Check Engine Light free.
What’s in the Box
The AWE Tuning S-FLO Carbon Intake includes the carbon fiber airbox itself, the AWE Tuning S-FLO Filter, and all necessary mounting hardware.
Photos
Availability
The systems are available now, either online at www.awe-tuning.com or through AWE Tuning’s global network of incredible dealers and installation centers, right here (put in your zip, find your local AWE Tuning dealer).
Questions? AWE Tuning BMW Performance Specialists await! 888.565.2257, performance@AWE-Tuning.com.
