02-17-2020, 11:10 PM | #1 |
Rep 14
Fitment question
Hello beautiful people!
I need some advice from you fitment experts! Struggling to find a suitable set of wheels in the land of australia. Will the following fit (with minimal poke)? AME Tracer GTV F: 18x8.5 +38 with 225/40/18 R: 18x9.5 +45 with 245/35/18 |
02-18-2020, 10:30 AM | #2 |
Rep 294
Drives: 2019 M240i Coupe RWD
245 is the minimum recommended tire width for a 9.5" wheel. So you will have a somewhat stretched look. That should help minimize any rubbing concerns though.
There are people out there that claim they've put 265s on ET45 rims with no rubbing. It certainly gives a flush look (not quite poking). So you could probably go to 255 or 265 width tires. I'm a little skeptical on the ET45 with 265 though. I bet if you had two adults in back seats there would be rubbing around turns or over large bumps. |
metzo1127.50 |
02-24-2020, 03:29 AM | #3 |
Rep 14
Hi! Thanks for the reply!
The wheels are no longer available to me so i've gone with a different style... Would square set up with 18x8.5 +38 be suitable? I was thinking of purchasing the Work D9R's with a medium dish.. |
02-24-2020, 12:15 PM | #4 |
Rep 294
Going to be a little close with the 38 offset. You looking to do square tire sizes as well? 225 or 235mm width max, limited by the front clearances, would be my guess without rolling fenders or going negative camber.
04-08-2020, 07:20 AM | #5 | |
Rep 14
18x8 +40 18x9 +50 Fits like a glove, but I'll probably put wider tyres on them next service! |
04-08-2020, 09:03 AM | #6 | |
Rep 294
Finally put my new wheels on this weekend. Also fits like a glove. 18x8.5 +45 -3mm spacer w/ 235-40 MP4S 18x9.5 +58 -5mm spacer w/ 265-35 MP4S |
04-10-2020, 12:45 PM | #7 |
DisplacementReplacement
409
Rep 1,100
Question: Is the rear spacer necessary or preference> great look btw...
2020 X3M /// MHD Tune
Prior Bimmers 2017 240XI Hybrid / FBO / MHD E40 2015 235XI FBO / MHD E30 2009 335XI FBO / COBB / E30 |
04-10-2020, 01:39 PM | #8 | |
Rep 294
According to Apex, you either had to install the spacer or you had to trim the shock boot. After installing the wheels and reaching in and feeling between the tire and the shock, I can confirm it's very close, but not touching. I can believe without the spacer it would be touching. Trimming the shock boot, probably not a big deal, but I like the more flush look with the spacer. |
04-14-2020, 06:11 PM | #9 | |
Rep 6,702
-Tom
Wheels /// Accessories /// Vehicle-Specific Fitment Guides /// Careers |
MassNerd171.00 |
04-15-2020, 12:07 AM | #10 | |
Rep 14
😬 I'm looking to switch to the same tyre set up (or at least 255s rears) at the next service |
MassNerd171.00 |
