2Addicts | BMW 2-Series forum Classifieds Members Classifieds Engine / Drivetrain / Exhaust / Bolt-ons DINANTRONICS Sport Performance Tuner for N20/N26 and N55 Engines (BMW ‘F’ Series)
      07-07-2019, 10:16 PM   #1
Steveoson1
Shipping Costs Included
Dinan Sport, upgraded to BM3 and no longer need it. Used on 2014 M235i with no issues. Easy to install and remove.
DINANTRONICS Sport Maximum Gains (N20): Up to 30 HP, 50 lb-ft of torque.
DINANTRONICS Sport Maximum Gains (N55): Up to 30 HP, 40 lb-ft of torque.
DINANTRONICS Sport is the boost controller for the masses. Its simple design/execution allows for easy installation/removal that can be performed in a blink of an eye and yields results you will be sure to feel, and enjoy, from the get go. Coupled with Bluetooth capabilities right out of the box that allows for user controlled adjustability and a live boost monitor to keep track of the action its a value proposition that is unequaled in the marketplace.
DINANTRONICS Sport plugs into a single sensor which lends itself to a very quick and and discrete installation, or removal, should the need arise. Not only does this connection method offer a simplified install but also effectively utilizes the factory DME, in tandem with itself, in order to re-map boost, fueling, and timing for optimal performance. Once installed DINANTRONICS Sport enjoys connectivity to various smartphone devices courtesy of its built-in Bluetooth Smart system. From the free app one has the freedom to reduce stock boost for valet duties or crank up the boost all the way up to the "race" setting for maximum enjoyment… or anywhere in between. Regardless of what setting is chosen there is a power level for everyone. Also within the app the end user has access to a live boost monitor which streams boost data in real time to the phone very similar in appearance to the sport gauges on the iDrive. Not only will you be able to feel the difference but now you can see it as well!
Perhaps best of all, the unit automatically detects which engine it is installed upon and loads the approprate mapping. Effectively making a single unit compatible with an extremely wide range of applications making switching to a new vehicle, sharing with another, or selling the unit a breeze.
Benefits of the DINANTRONICS Sport Performance Tuner for BMW N20/N26 & N55 Engines (F Series ONLY):
+ Up to +30 HP and +50 lb-ft (N20), Up to +30 HP and +40 lb-ft (N55)
+ Bluetooth smart (Android and iOS Compatible – Android OS8 "Oreo" not supported)
– Live boost monitor
– Multiple power settings to choose from (Sport, Sport+, and Race).
– Valet / parental control modes (-3 PSI)
+ Quick, easy, and discrete installation
+ Automatically detects engine type and loads appropriate mapping
+ CARB EO submitted and approval is pending.
      07-16-2019, 09:03 PM   #2
243Racing
Drives: M2
Did you dyno before & after?
      07-18-2019, 09:46 AM   #3
sdull
Drives: 330Ci - ZHP model
Hi Steve - I'd like to buy your Dinan Sport tuner - could you ship to Lyle WA this week or early next week?
I am staying there for a couple of weeks starting this weekend.
Could pay via PayPal
thanks, Steve D
