2Addicts | BMW 2-Series forum Technical Topics DIY and Coding Discussions New battery causing problems
      05-12-2023, 02:16 PM   #1
jb-slow
Drives: m235i
I just put in a new antigravity battery, I followed this video:
I installed the same battery and coded in and registered all the same settings as the video. The car is now throwing over voltage codes in a couple of modules and resetting, the weird part is it only happens when I hit the brakes, otherwise the car acts normally. Im seeing 14.8 volts when running. I could really use some suggestions to figure this out.
      05-13-2023, 12:44 PM   #2
TheNine90
Drives: bmw
You registered the battery as 60ah? What tool did you register the battery?
      05-13-2023, 04:23 PM   #3
jb-slow
Drives: m235i
Everything exactly the same as the video using bimmercode/link
      05-14-2023, 02:46 AM   #4
TheNine90
Drives: bmw
Normal battery voltage should be 14.5v. What fault codes you are getting?
You can monitor battery voltage and alternator output to check at different scenarios.
      05-14-2023, 09:43 AM   #5
jb-slow
Drives: m235i
14.8 and immediately sets over voltage codes in almost everything. Hvac, steering, radio, brakes, front collision system, the engine sound even changes. I swapped back to the old battery and everything is fine again. I'm waiting to see if antigravity has any ideas or if a replacement is needed.
Search this Thread:
