2Addicts | BMW 2-Series forum Technical Topics B58 (M240i) Engine, Transmission, Exhaust, Tuning Injectors B58 & brake question
      08-26-2024, 05:36 PM   #1
kennungesser
Drives: 2017 M240i Xdrive
Hey there.
2017 M240 xdrive, fully stock. Haven't had a bit of problem with it yet, and sitting at 50,650 miles on the clock.
Couple of questions.
Replacing the disks and pads all the way around. I know to loosen the brake reservoir cap, but once I do that, do I need to bleed the brakes after? I've done this back in 2008 on an 06 TSX, but can't remember. I don't THINK so, just want to make sure.
Question 2.
I am going to replace the injectors around July of next year unless something happens and I need to do it sooner. Being a stock engine with no mods, would I see any benefit of going with "matched" injectors, or just order the replacements from FCP Euro. Going for longevity here, and the car is fast enough for me as it is.
thanks and have a good one.
      08-27-2024, 08:43 AM   #2
Dom147
you don't need to loosen the brake reservoir cap when only doing your disks and pads. It may make it easier to push the piston but I haven't had an issue with doing it while its closed.
The B58 doesn't typically have injector issue especially at 50k miles. If you suspect something is up then I'd first look at spark plugs and ignition coils. Replacing the injectors is somewhat labor intensive with special equipment and a lot of TTY screws. If you do end up going the route of replacing them, the stock injectors will do just fine.
      08-27-2024, 06:14 PM   #3
kennungesser
Thanks Dom147, I appreciate the response and information!!
Dom147123.50
      08-30-2024, 04:24 PM   #4
ZHP to B58
ZHP to B58's Avatar
Drives: M240i
Stock injectors are fine. Also, the only issues I've seen online were from those who ran questionable custom ethanol tunes, and/or had abused the car regularly. Or didn't have the proper ethanol blend for the tune they're running. Haven't come across a stock B58 yet that had injector issues.
My 2017's at 105k miles with the stock injectors. Occasional PEA additives used and no issues. MHD stage 2 HPFP, xHP stage 3, catless downpipe, TU HPFP.
      09-02-2024, 08:33 AM   #5
MarcoZandrini
Drives: 2018 M240i
What brand/s of gas do you put in the car? It matters.
      09-20-2024, 06:20 PM   #6
n55david
n55david's Avatar
Drives: 2017 m240i, 2015 X3 x35i
2017 m240i xDrive  [0.00]
2015 X3 x35i  [0.00]
2015 335i xdrive  [0.00]
Originally Posted by kennungesser View Post
Hey there.
Question 2.
100% go aftermarket
2017 m240i xDrive 10.67@132.32mph w/bm3
2015 335i xDrive 10.95@124.99mph w/bm3 - SOLD
2015 X3 x35i pwg 12.96 catless w/bm3 stage 2 93 ots
IG: @n55david For pics and updates!
Youtube: @ n55david For videos or Racing etc
Search this Thread:
