2Addicts | BMW 2-Series forum Technical Topics B58 (M240i) Engine, Transmission, Exhaust, Tuning B58 downpipe/midpipe clamp (nut) spinning freely
      07-29-2024, 11:34 AM   #1
Evanp363
Drives: 2017 M240i 6spd RWD
I had to put a ton of torque on the nut for it to start moving in the first place, but now the bolt just spins whenever i try to loosen the nut. i can’t find a size socket that fits on the top of the bolt. i don’t know what to do.
      07-29-2024, 11:49 AM   #2
Dantesboyz
recovering e36er
Dantesboyz's Avatar
Drives: 2017 M240i Xdrive
  [10.00]
2017 ///M240i XDrive  [7.25]
Might have to get a wrench/ratchet on it from both ends.
If you got it broke loose a few turns and then this happened... it's likely the slots of the clamp are not holding the hex head of the bolt on the underside, no worries.
Sometimes the clamp doesn't spring open as you loosen the bolt, so the gravity let's the "trapped" hex head move out the slot of the clamp where it can spin freely.
Hope that helps
2017 F22 M240i, Xdrive, M Performance Package
Active Autowerke Downpipe, Dinan Carbon Fiber Intake, Dinan Carbon Fiber Turbo Inlet, Dinan Mid-pipe, xHP Flashtool, MHD Stage 2
To do next list- #1- Wheel Spacers & Tires, #2- B58 TU Pump, #3- Flex Fuel Kit
      07-29-2024, 11:52 AM   #3
Evanp363
Hope that helps
Yeah i believe that’s what happened as well. i just have to figure out what size the hex is. none of my sockets fit i think because it is rusty
      07-29-2024, 01:13 PM   #4
Dantesboyz
recovering e36er
Dantesboyz's Avatar
  [10.00]
Trying to remember what mine was from last year, I think a 13 or 14 mm.
Kern might reference in his dp install video
kern YT DP band vid
      07-29-2024, 02:43 PM   #5
Evanp363
kern YT DP band vid
I just checked from the engine bay and the top is a carriage bolt. I’m not exactly sure how to get it out now because I think the part of the clamp that was holding the carriage bolt still is probably broken or it just wasn’t supposed to be a carriage bolt in the first place. It’s completely smooth on the top and I can’t get anything to hold it still.
Search this Thread:
