2Addicts | BMW 2-Series forum Technical Topics B58 (M240i) Engine, Transmission, Exhaust, Tuning BM3 Maintenence Schedule
      06-23-2024, 02:52 PM   #1
tcollier91
Drives: M240i
I've had BM3 on my car for about 20k miles now (car is at 32k). I did plugs when I went stage 2, but other than oil changes at 5k and checking the coolant regularly (no loss) I haven't done much. What other accelerated maintenance are you doing for your cars? I'm about to go stage 2+ and would like to make sure everything's in top shape before doing so.
      06-24-2024, 08:45 AM   #2
MarcoZandrini
Drives: 2018 M240i
I think it depends on the oil and filter. Are you using a MANN oil filter? Aftermarket filters (e.g., Fram, Puralator) aren't as good as MANN filters. Also, what oil are you using? It matters. I run Ravenol VMP 5W30. Used oil analyses show this to be a superb oil.
      06-27-2024, 11:08 PM   #3
tcollier91
Drives: M240i
My last oil change was done by a liqimoly shop, 5w35. Not sure on filter. Anything besides oil changes? Spark plugs, coil packs…
      08-23-2024, 10:16 AM   #4
SpencerC_6MT
SpencerC_6MT's Avatar
Drives: '17 M240i 6MT
2017 BMW M240I  [0.00]
Leave the coils/plugs alone until they start acting up, I'd say. If you're going beyond just dp/tune, replacing them might be wise, but otherwise unnecessary. 1 stage colder plugs often burn out 5x faster, and the power/reliability gains for fresh coils are minimal. For reference, I'm at 84k miles with original coils and plugs have 34k on them. I only tuned it recently, to be fair, but no issues so far.
I will note that I'd suggest doing your oil sooner than the car suggests. Personally I do every 5k miles. Also look into having your transmission/diff fluid (and transfer case, if applicable) replaced every 30-50k. BMW claims that it's "lifetime fill"... yea right.
2017 BMW M240i 6MT Slicktop | Wavetrac 3.46:1 Limited-Slip Diff - DinanTRONICS Sport Boost Controller - H&R Sport Springs - Millway Street Camber Plates - Agency Power Intake w/ Paradigm Engineering Turbo Inlet
      08-30-2024, 02:11 PM   #5
UtahBimmerBoy
UtahBimmerBoy's Avatar
86
Drives: 12' 328i,17' 340I, EQE 350 SUV
Doing regular fuel additive or oil additives every 15k miles or so wouldn't hurt, you could also add an oil catch can to prevent any carbon build up.
I also have ALWAYS used Liqui Moly Moly-Gen for my oil changes as well as MANN filters, my coworkers at BMW also all use Liqui Moly for their B58's as well.
Search this Thread:
