08-09-2018, 12:22 PM | #1 |
Rep 7
Staggered setup, which offset to choose?
I'm looking at getting a set of staggered Enkei Raijin, 18x8 38mm front and 18x8.5 38mm rear, with the stock size tires, 225 up front and 245 rear (M Sport and THP car).
Is there any clearance issue with the THP setup and 38mm offset? Tirerack recommends 42mm but I'd like to go out to 38mm. |
08-14-2018, 07:57 PM | #2 | |
Newer 2er
296
Rep 474
Drives: 2017 M240i (Sold)
I'm running 265 rear on 18x9 et 50 with no issues as well. Both front and rear fitment are relatively conservative (no poke) compared to what you see on 2 series. Your proposed set-up rear will give you a few millimeters of poke at the rim, but will probably look pretty flush. Scrub radius will change by 14mm, which is a lot, but not sure how that would impact handling since it is in the rear. https://www.wheel-size.com/calc/?whe...cl=30mm&sr=0mm
2017 BMW M240i (Sold)
2021 F-150 Raptor 2017 Porsche 718 Cayman S 2017 Audi Q5 Last edited by RotorOver; 08-14-2018 at 08:10 PM.. |
08-15-2018, 09:47 AM | #3 | |
Rep 566
8x18 ET38 front and 9x18 ET44 rear are the magic numbers for the stock staggered tire sizes, both the way it looks and the way it handles. imho. (at least, I wouldn't go over 8x18 et37 front and 9x18 et43 rear). |
Denk1006.00 |
08-15-2018, 10:15 AM | #4 | |
Rep 823
08-15-2018, 11:56 AM | #5 | |
Rep 2,873
08-15-2018, 07:50 PM | #6 | |
Rep 558
08-15-2018, 08:43 PM | #7 | |
Newer 2er
296
Rep 474
https://www.2addicts.com/forums/show...1265503&page=8
2021 F-150 Raptor 2017 Porsche 718 Cayman S 2017 Audi Q5 |
08-15-2018, 10:18 PM | #8 | |
Rep 566
Alternatively, if you only widen the front track leaving the rear intact you get a more stable front end (relative to the rear) that translates into a less sharp turn in and a bit wider turn radius, less agile in tighter spaces/turns, but the rear end will let go easier relative to the front, especially when you apply throttle. You may try to think of it as in bicycle vs tricycle. Anyway, it's always about the balance of front vs rear. Last edited by x233; 08-15-2018 at 10:50 PM.. |
Maynard3848.00 |
08-16-2018, 03:41 PM | #9 | |
Rep 558
08-17-2018, 01:23 AM | #10 | |
Rep 61
I currently have 8"xET45 up front, albeit with 235/35R19 Sport Cup 2s, which are extremely wide. I have an 9"xET40 rear, with 265/30R19. This pokes and an ET45 would have been better. I am pretty sure you could go higher. Last edited by Sonertial; 07-12-2023 at 01:31 PM.. Reason: Bad info |
08-17-2018, 04:37 PM | #11 |
Rep 7
Thanks, I didn't get any replies for a few days so I ended up with the 18x8 42mm offset from Tirerack after chatting with them. They said the 38mm might poke a bit in the back, so I just decided to stick with their recommendation.
I'll have stock staggered tires but square rim sizes. 225 and 245 stock tire setup is what I'm sticking with, some brand new MPSS going on the rears once I get the rims mounted. Should fit perfectly, thanks for the advice all. |
