07-26-2018, 11:36 AM | #1 |
Rep 1,758
Drives: 30Jahre M5 plus a few more M's
Garage List 2022 BMW M5 CS [0.00]
2020 BMW M340i Xdrive [0.00] 2019 BMW M2 Competi ... [0.00] 2003 BMW DINAN S3 M5 [0.00] 2017 BMW 30 Jahre M3 [0.00] 2016 BMW M4 GTS [0.00] 2015 BMW 30 Jahre M5 [0.00] 1995 BMW M3 [0.00] |
Got my new wheel tire combo. Looks MUCH better than stock.
Apex arc8 18x8.5, 18x9.5 (5mm spacer) Michelin 4s 245/265 No rubbing on the street. On stock suspension. Very happy and highly recommend.
Current non-BMW's
20 Jeep Grand Cherokee 03 Cooper S (Maxi Tuned 50bhp) 60 Impala (43k orig mi) 15 Turbo S (Kobb tune and Kline exhaust) |
07-26-2018, 11:39 AM | #2 |
Rep 532
Extremely nice. Is it lowered? Which ET does the front wheel have? Stock Camber?
I want a 245 square setup with 8.5j ET40, but im not sure at all, if that will fit under the front. Last edited by Erebor; 07-26-2018 at 11:48 AM.. |
07-26-2018, 11:41 AM | #3 |
Rep 823
07-26-2018, 01:53 PM | #5 |
Rep 558
If it's these on the front, then the offset is ET38:
https://www.apexraceparts.com/18x8-5...c-8-wheel.html
NOT2DAY117.00 |
07-26-2018, 02:41 PM | #6 | |
Rep 1,758
Stock alignment and suspension. Don't feel like I need to lower or reduce comfort with bigger wheels now with these "fatties" (cosmetically). Fills the wheel well better now.
Current non-BMW's
07-26-2018, 04:33 PM | #8 |
Rep 558
So, no spacer in the front, correct? What ratio are the front tires 245/??
07-26-2018, 04:34 PM | #9 |
Rep 823
Any idea if the same offset going with a square set-up with the 8.5's would work or spacer will be needed?
07-26-2018, 04:50 PM | #10 | |
Rep 1,758
Current non-BMW's
07-26-2018, 04:52 PM | #11 | |
Rep 1,758
Current non-BMW's
07-26-2018, 04:53 PM | #12 |
Rep 1,758
Current non-BMW's
07-27-2018, 02:13 AM | #13 |
Rep 2,601
Looks great!
Did you need the spacer on the rear or was it just for looks? |
07-27-2018, 08:21 AM | #14 |
Rep 1,758
Need it for inside clearance in the rear, apparently. Looks good too......
Current non-BMW's
07-27-2018, 09:04 AM | #15 |
Rep 908
Rear is 265/30 or 35?
07-27-2018, 12:44 PM | #17 |
Rep 233
Drives: '18 M2 LCI
Wheels look great! I'm looking at that set up or a square setup with 245's all around. Off topic, but what spoiler is that?
'18 M2 LCI 6spd
07-27-2018, 03:16 PM | #19 |
Rep 1,758
Current non-BMW's
WolfGTI688.50 |
07-27-2018, 03:23 PM | #21 |
Rep 1,758
Don't think you need for 255
Current non-BMW's
07-27-2018, 03:24 PM | #22 | |
Rep 1,758
Current non-BMW's
