07-17-2018, 11:45 AM | #1 |
Rep 6
m235 all season tire size option,
my car is 225 40 18 front. and 245 35 18 back.
if I go square with stock rim. what's the best size. my thoughts is 235 40 18 . any advise? |
07-28-2018, 06:53 AM | #3 |
DisplacementReplacement
406
Rep 1,100
I think the 235/40 18 would be fine on the 7.5 inch rim, IMO...
2020 X3M /// MHD Tune
Prior Bimmers 2017 240XI Hybrid / FBO / MHD E40 2015 235XI FBO / MHD E30 2009 335XI FBO / COBB / E30 |
07-28-2018, 01:40 PM | #4 |
3621
Rep 3,590
It will fit, but it is not an approved combination by the tyre manufacturers. The tread will be more rounded, the risk of popping a bead due to the sidewall being angled beyond design limits and excessive centre tread wear are all possibilities. Grip compared with a 225/40-18 may be no better and may be less due to the tread not laying flat enough on the road with the pinched sidewalls.
Overall the answer is to use the designed rim width for the tyre, as specified by the tyre manufacturer. |
07-30-2018, 06:44 PM | #5 |
Rep 2,873
No reason to not just do staggered for the snows too, if you are going to dismount and replace summer tires. But repeatedly swapping tires onto rims can cause a lot of wear and tear to the tires. Best in the long run to get a dedicated set of winter wheels/tires in a narrower square setup (if not using the staggered ones - the diff in width isn't worth a new set of wheels)
