03-17-2017, 02:58 PM | #309 |
Rep 8,364
04-01-2017, 11:23 AM | #312 |
Rep 4
Inccorect activation code
Hi all,
Like many others I arrived here from searches etc., I like to tinker a bit so thought I would give it a go and as a result bought my OBDC2 interface and reinstalled an HP laptop lying around as XP 32 bit. After a little faffing around (read missing how to connect to the car correctly) managed to read and save off the DE.FSC file. Used nbt.exe DE.fsc 0xA8 0x28 DXXX121 < dummy vin in this line Got the return line New encoded FSC etc with the 20 digit code, when entered I get a message saying incorrect code entered. I rechecked it and re-entered it to the same result (I am assuming it is an I not a 1 in the codes as I am sure I have read that they don't use 1 or 0 in activation codes for this reason. 2012 F10 528i with NBT head, and 2017-1 maps on the 32gb stick. I have gone over this a couple of times now and searching isn't making it any more understandable, I am hoping someone here can point me in the right direction. Any help greatly appreciated. thanks in advance Biffa773 |
04-01-2017, 11:29 AM | #313 |
General
10445
Rep 40,771
Drives: 2018 Alpina B6 650ix GC
0xA8 0x28 is North America NEXT 2017-1. 0xA9 0x29 is Europe NEXT 2017-1.
2018 F06 Alpina B6 650ix GC; Space Grey; Vermillion Red Nappa Leather; Executive; B&O; Driving Assistant 2017 F15 X5 xDrive50i MSport; Glacier Silver Metallic; Black Dakota Leather; Executive; B&O; Driving Assistant; RSE |
04-01-2017, 11:39 AM | #314 |
Rep 4
Cheer
I came back in from the car giving it a another go and was still on the page, certainly didn't expect to see anyone having replied, awesome response thanks. Will run again with those, and update with results, cheers UPDATE: Works perfectly map updating as I type, thanks again for the help Last edited by Biffa773; 04-01-2017 at 12:23 PM.. |
04-09-2017, 09:32 PM | #319 |
Rep 303
Trying to generate a code for the North American Premium 2017-1 CIC, I think the lookup.xml is old? The one i have only has upto 2014-2 for NA Prem in it. How do I modify it to do a 2017-1 code?
04-13-2017, 06:37 AM | #321 |
General
10445
Rep 40,771
You are searching for something not even released yet.
04-15-2017, 08:32 PM | #324 |
General
10445
Rep 40,771
FSC Generator does not generate ROUTE or EVO FSC Codes, at least not correct ones.
04-15-2017, 10:18 PM | #325 |
Rep 116
04-15-2017, 10:45 PM | #326 |
General
10445
Rep 40,771
DE File is only for NBT Head Unit, which is NEXT Map. EVO Map is for NBT2 Head Unit, and NBT2 Head Unit has an F0 Navigation Enabler file for ID4, and in case of ID5 it has no Navigation Enabler file at all.
Thebush12153.00 |
04-17-2017, 04:36 PM | #327 |
Rep 982
Does DE file change each time?
Do you need to generate a new DE file for each update, or do you just need to run the NBT.exe with the new hex codes for each version?
04-17-2017, 04:47 PM | #329 |
General
10445
Rep 40,771
Same DE File, just run with new hex codes.
spike5150421.50 |
04-19-2017, 03:57 PM | #330 |
Save the manuals!
6015
Rep 6,746
Does anyone have a link to the latest 2017 CIC Road Map North America Premium maps?
'16 M3 | '23 718 Spyder Past: E92 M3, F87 M2, E39 M5, etc |
