03-23-2022, 09:09 PM | #4423 |
Rep 50
Drives: '24 M3 CS, '18 M240xc
because my BavSound upgrades were so disappointing, and because i didn't want to spend $1000+ on a replacement amp to maybe be less disappointed, i decided to try out the Technic PnP adapter so i could see if my 26 year old Fosgate amp and JL sub would give me the extra boom i have been craving.
quick review: i would pass longer review: the Technic PnP site lacks important details, and support doesn't get back to you. forum searching reveals 'Standard LOC' is if you are going to use one external amp. 'Premium LOC' is if you are going to use two external amps. but the Technic PnP widget did what it was supposed to do: it gave me RCAs to and a turn-on wire to feed to an external amp. the BavSound instructions were followed on how to remove the necessary interior trim bits. and i did have to undo the trunk rear strut bar. i was unprepared for the amount of sound designing that would go into this upgrade. in previous cars i have always had head-units that had sub controls and things magically worked. tweaking gains and crossover points and volumes and phases and different DSP settings and getting in and out of the car over and over and over again to fiddle with things in the trunk and then the dash is exhausting / maddening. all this should probably by a professional. and definitely with a battery tender. i also chose to add a PAC LC-1 volume knob to try and wrangle the overload. i left the knob in the trunk because i am not interested in a tweak-every-song setup. i am more interested in a set-and-forget experience. and, of course, it's all about the source material. adding an amp and sub still doesn't make old music recorded with no bass sound any better. depending on the waveform, yes, your rear-deck will rattle. but when it sounds good, it sounds amazing. but it's too much. too much space lost in the trunk, too much bass, too much fiddling, and too much waste — the amp and the sub are largely wasted when all you want is a little more boom and aren't interested in annoying other people. |
03-24-2022, 05:33 AM | #4424 |
Rep 8,942
Any ticking noise with the slots? I have the OEM BBK on my wagon and it's annoying as hell, need a different upgrade for the convertible.
03-24-2022, 01:35 PM | #4425 |
Rep 913
2 days in and about 50 miles on them including bedding in, so far no ticking noticed. I am guessing a good indicator will be my trip to Deal's Gap in 3 weeks.
Rogue Engineering SSK & transmission mounts, WaveTrac LSD. Ohlins R&T coilovers, Turner monoball thrust arms, F87 LCAs, GC camber plates, Superpro subframe bushings, Megan Racing adj. RCAs, delrin differential bushings. Stoptech BBK 6 piston (f) 4 piston (r). |
03-24-2022, 02:24 PM | #4426 |
Rep 184
Took my ‘19 240xi Coupe in for the three year service, today.
This is my last “free” service. First time I have to say this. All of my previous BMWs had “free” four year service. I have 22k miles on it. Inspection revealed its solid, free of leaks and the brakes are about 1/2 through their life cycle. I live in a very hilly neighborhood so I expect about 45k miles b/4 I have to change brake pads. For reference, my ‘17 Macan S required new brake pads & rotors at 22k miles. That was a $2k bill. No joke! Thus far, this has been a great car! My dealer had very few new cars on the lot. Strange times! I considered trading it in on a ‘22 X2M 35i; however, the X2M 35i is not available until MY ‘23. It’s amazing how some new MY fiscal cycles start in March/April. I’m still considering this move in about a year, b/c I plan to give the new SAV to the Mrs. I ordered a new car in June of last year & still don’t have an allocation! Strange times… Cheers/B
Previous BMWs: '87 325is; '06 X3; '09 X3; '11 328i x-Drive; '12 R1200 RT; '13 128i; '13 X3 35i MSport
Other/Current: '19 Porsche 991.2 TT; '21 Jeep Wrangler JL80A; ‘23 Lambo Huracan EVO RWD |
03-24-2022, 03:19 PM | #4427 |
Rep 8,942
You'll hear it most when you're driving up against something solid e.g. a divided highway with a concrete wall in the middle.
03-24-2022, 04:22 PM | #4428 |
Rep 913
Yup I figured, I'll pay attention to it and let you know.
03-24-2022, 09:54 PM | #4429 | |
Thaumaturge
181
Rep 211
BUT, I drained all the fluid and refilled with blue stuff. Neither says there is anything but Methanol, Ethylene Glycol, and water. But the Prestone set the warning off and the Blue cheap stuff, all is good. I have no idea how the yellow Prestone -27 behaves. But I KNOW the -34° is bad for my 2014 M235i. ///Rich Last edited by Rich.Wolfson; 03-25-2022 at 09:47 PM.. |
03-25-2022, 02:53 AM | #4430 |
In search of the perfect cup of coffee
152
Rep 213
Got mine towed to the collision center after someone ran into her while parked curbside in front of my house. The total insurance bill will be $10,250.
03-25-2022, 08:28 AM | #4431 |
Rep 1,226
2019 M240i RWD-- Not done yet but this coming Tuesday having a local import shop install an aftermarket heat exchanger from Burger MS, and some Apex EC-7 satin black wheels with Mich Pilot Sport 4s. Going 235's in front and 265's in the rear. So excited to see what it looks like and how it drives. After that will see if there is enough clearance for some lowering springs. Next things on the list are: rear lip, front splitter, and next year 80% certain will be going with a bigger turbo. Good times.
2024 M2
2019 M240i- Sold |
jLona24029.50 |
03-25-2022, 11:31 AM | #4432 |
Nobody in particular
105
Rep 103
03-25-2022, 06:32 PM | #4433 |
152
Rep 213
03-26-2022, 03:55 PM | #4434 |
Rep 1,219
Drives: 2015 M235ix
Always look on the bright of life!
03-26-2022, 09:04 PM | #4435 |
Rep 913
Drove against a divided highway (concrete barriers), at about 50mph for about 7 miles today, no ticking.
dradernh4470.00 |
03-27-2022, 05:57 AM | #4436 | |
Rep 8,942
03-27-2022, 08:08 PM | #4438 |
Rep 345
04-03-2022, 12:46 PM | #4439 | |
Rep 1,226
Good news is the new wheels are sweet and no issues with rubbing.
2024 M2
2019 M240i- Sold |
04-09-2022, 10:19 AM | #4441 |
Rep 913
Just updating - still no ticking.
04-09-2022, 07:20 PM | #4443 |
Rep 35
When I bought the car it had horrible green kidney grills and lower plastic. I FINALLY replaced the grill today and have the oem plastic lowers coming in soon.
Also ran into a new M240 and took a couple of side by sides. As I was taking them (at the grocery store) the owner walked up to me and told me how much she loved her car which replaced her old one, pretty cool! Next on the list is new center caps for the wheels and new rotors/pads. |
11
Heitzer103.00 Ron Jeffries388.00 WolfGTI716.00 E46ZHP254.00 qlaval52.50 GoldfishRT75.50 freakystyly3062.50 MLJR235116.50 lateapex'er123.00 sammage1.00 Sean@PSI2151.50 |
04-10-2022, 08:33 AM | #4444 |
Rep 913
Thank you - Pedal seems firmer and more bite for the same pedal travel, I'll get to put it through its paces on some mountain roads in 10 days.
For comparison - I was running the Ferodo DS2500 pads with my stock brakes.
Rogue Engineering SSK & transmission mounts, WaveTrac LSD. Ohlins R&T coilovers, Turner monoball thrust arms, F87 LCAs, GC camber plates, Superpro subframe bushings, Megan Racing adj. RCAs, delrin differential bushings. Stoptech BBK 6 piston (f) 4 piston (r). Last edited by WolfGTI; 04-10-2022 at 08:44 AM.. |
