01-22-2019, 02:49 PM | #1 |
Rep 2,010
Should I heat my garage?
i've got a detached garage in Chiberia, and while it generally stays warmer than the outside, it does drop below freezing. Obviously cars are parked on streets in the freezing cold all the time, but is there any reason to keep the garage above freezing? Any long term benefits?
Current '21 DG X5MC, '22 X5M50i, '11 E90 M3
Recent Past '12 E92 M3 ZCP, '08 E93 M3, '18 F80 ZCP, '04 E46 M3 I think I have an M3 problem. |
01-22-2019, 02:50 PM | #2 |
Rep 591
Nah you’re fine. You are already covering it from the snow.
2018 F80 M3 6MT///Black Sapphire w/ Sakhir Orange Leather
2006 S2000 AP2 Laguna Blue Pearl 6MT |
01-22-2019, 03:19 PM | #3 |
///Multiple
2992
Rep 4,243
Drives: M4 Coupe | M3 | Z4M Roadster
Garage List 2006 BMW Z4 M Roadster [8.81]
2016 BMW M4 Coupe ( ... [10.00] 2018 BMW M3 (Euro D ... [0.00] 2011 BMW 335is Coup ... [10.00] |
No need, but if you're thinking that you can just put a space heater in your garage to heat it, I would strongly advise against that.
The Coupe: 2016 M4 | Sakhir Orange | Black Full Merino Leather | CF Trim | M-DCT | More | ED 5/13/16
The Sedan: 2018 M3 | San Marino Blue | Black Full Merino Leather | CF Trim | M-DCT | ZCP | ED 7/18/18 The Roadster: 2006 Z4 | Interlagos Blue | Black Extended Nappa Leather | Carbon Leather Trim | Purchased 7/19/12 |
01-22-2019, 03:23 PM | #4 |
Rep 2,814
I’m building a new garage at the moment and have centrally heated it with 2 radiators. My motto was if I’m building a man cave, I want to be warm
2020 M4 competition Mexico Blue / Opal white ultimate pack, full M perf carbon kit, MP HAS, Carbon Ceramics, 763M with cup2’s.
Instagram c1_cdg |
01-22-2019, 03:50 PM | #5 |
Rep 616
Instead of heating the entire garage and paying high utilities, I suggest using an electric blanket to keep your car warm and cozy. That's how I keep my wife from jacking up the thermostat in our house.
01-22-2019, 05:50 PM | #6 | |
Rep 2,010
i'd get a heater meant for permanent use. You can get a 50K BTU one for a few hundred bucks..
SD ///M42992.00 |
01-22-2019, 05:57 PM | #7 |
Rep 2,147
This is a good opportunity to ask about tires.
Is there any issue with having summer tires in the garage with temps this cold? Not talking about r comps, but MPSS level. |
01-22-2019, 06:38 PM | #8 | |
///Multiple
2992
Rep 4,243
Short answer: no
ntg442888.50 |
01-23-2019, 06:40 AM | #9 |
Rep 512
Drives: '20 F82 M4 '23 G05 x40i MSport
I'd only heat the garage if you plan on spending time working in there. Some guys like to hang out in their garages. I don't. My garage got down to 26 degrees this past weekend when it was -8 degrees outside. This morning, back up to 41 degrees inside the garage, outdoor temp 20 degrees. The car is fine. It's not getting hit with wind, blowing snow, sun, etc. It actually looks majestic next to my X2 right now which looks like a car driven in snow for 4 straight days.
01-23-2019, 08:22 AM | #10 | |
Rep 208
01-23-2019, 11:31 AM | #11 |
9153
Rep 14,522
my coworker has a pole barn which is basically his mancave and has heated floors. he only did this because he spends 95% of the day in it than his house along with his cars and projects. so it makes sense
~F90Conversion~21"3Piece Forged AvantGardeWheels~KWV1Coilovers~CQUENCE slotted/drilled rotors~GoodridgeStainlesslines~MeisterschaftQuadEx haust~Akrapovic 4"tips~VRSF DP~VRSF CP~TurboSmart BOV~K&N filter~CarbonFiberExteriorComponents~GladenAlphaCo mponents~MatchUp7BMW~Punch P300-12T~ Follow me on Instagram: lsturbointeg |
01-23-2019, 11:45 AM | #12 |
Rep 5,577
If I were to have a car that I drove on salt applied snow covered roads, I wouldn't want to drive that car into a heated garage. Doesn't the rust process increase over the freezing point? and think at about 52 degrees and above the corrosion process is increased even further.
01-23-2019, 11:48 AM | #13 |
Rep 1,966
is the reason for wanting to heat the garage to ensure your car starts up when it's cold....maybe a block heater is the solution. Cheap to use, easy to install and your car will start easily and you'll get heat really quickly.
01-23-2019, 12:57 PM | #14 | |
Rep 2,294
2018 340i xDrive M Perf Edtn Sunset Orange
Previous BMWs - 19 others since 1971. |
01-23-2019, 01:30 PM | #15 |
Rep 1,118
I keep the garage around 4 to 5 degrees C.
Just to keep any cans, bottles etc from freezing. My garage is well insulated, so the cost is minimal. I also have a large kerosene heater if I want to do work in there. It heats up very quickly, then the electric heater just maintains! |
01-24-2019, 07:59 AM | #18 | |
Hoonigan
6818
Rep 3,000
Drives: '09 328i, '98 Wrangler
I bought a propane "torpedo" style heater from home depot when it was on sale for $100. I hook it to one of those small gas grill propane tanks and let it run for 15-20 minutes before I work in the garage. Best $100 I've ever spent. I changed my oil in a T-shirt the other night when it was 5 degrees outside and windy.
"Yeah, but your scientists were so preoccupied with whether or not they could, they didn't stop to think if they should."
-Dr. Ian Malcolm, Jurassic Park |
01-24-2019, 08:09 AM | #19 |
11817
Rep 23,187
I had electrician come in and wire up heater for garage primarily so tires, track tires, wouldnt get below recommended temp. Also nice to have it 50 plus all the time just for work.
01-24-2019, 08:26 AM | #20 |
Rep 381
My garage itself isn't heated, but I have a pass-through door between it and the pantry, and a HVAC vent in the pantry.
If I'm going to be working in the garage for a while, I just leave that door open and it'll bring the temp up to a comfortable level. |
01-24-2019, 01:08 PM | #21 |
Rep 87
Garage is against my "semi-detached" shit little British house, but only accessible by going outside through my garden. I keep it pretty warm since we are constantly doing laundry and the tumble-dryer seems to never stop running.
It's hilariously narrow, so can't park my 6er in it and open the doors. Would only be able to enter/exit car via convertible roof. Living over here for so long has made us so particular with the house we're building back in The States. Going all out.. ha New US garage will be insulated and on HVAC circuit, but able to be isolated. |
01-24-2019, 01:10 PM | #22 | |
Rep 87
My aunt's house had this back in the 70s and was considered 'new age'. Was really nice for melting snow in the winter and having warm patio around the swimming pool on cool autumn nights. |
