09-29-2018, 11:54 AM | #1 |
Rep 44
Noticeable lag after charge pipe and street FMIC install
So! Yesterday I went about the PITA task of swapping the old in with the new. I'm running the JB+ on the 4 psi setting currently. I ensured all the hoses and clamps were snug, and the car isn't throwing any codes after 5 driving cycles. After install of the jb+ with only the BMS intake, car was brought to life. Comfort mode was sport mode and sport mode was a rocketship. Now comfort mode throttle response requires more to rev, and it feels like I've lost low end. Is there any way to tell if there is a leak? Shouldn't it throw a code if the MAF isn't seeing enough air or cool enough inlet temps? OR does the size of the VRSF FMIC require more air, thus killing turbo spool?
Has anyone else experienced this? |
09-29-2018, 02:17 PM | #3 |
Rep 44
10-03-2018, 08:26 PM | #6 |
Rep 191,156
10-04-2018, 02:19 PM | #7 | |
Rep 109
10-04-2018, 06:00 PM | #8 |
Rep 5,262
10-05-2018, 01:54 AM | #9 | |
Rep 44
10-05-2018, 04:18 AM | #10 |
Rep 524
Did you find a leak? Where was it? I'm chasing one now.
2019 M2 Comp, MT, BSM
2015 X5 Msport, CB (Hers) 2014 M235i MT, BSM, MPE, Dinan Springs (Sold) |
10-05-2018, 09:00 AM | #11 |
Rep 44
Wasnt a leak. Mechanic plugged into the vacuum on the charge pipe and tested it, all sealed up. Car was used to driving with restrictive factory charge pipe and shit its pants when all the extra air from my tuner/less restrictive charge pipe. I reset the driving/shift characteristics of my comfort mode and shes back to driving like a champ. What kind of issues do you have?
10-05-2018, 09:42 AM | #12 | |
Rep 524
10-05-2018, 10:28 PM | #14 | |
Rep 524
I guess I didn't have a boost leak. I check target boost vs actual and they were very close. I also looked at older logs and I'm hitting the same PSI. I know I've seen higher numbers on the BM3 dashboard(15), but the logs were lower (13)
