[HELP] BMW M235i - Head Unit Blue Screen - Programming Abort |
07-31-2024, 01:03 PM | #1 |
Rep 5
Hello everybody, I am trying to find a solution for fixing my head unit on my BMW. The head unit currently turns on with the vehicle in the on/run position but has a blue screen that says "Magneti Marelli" which I am assuming is the manufacturer for the head unit itself.
So far here is the following steps I have tried as far as recovering the head unit. - I attempted to inject the CAFD file manually into the HUB via E-sys with programming data 4.39.20, it started the process and crashed at 41-45% every time. I have screenshots of all the errors from e-sys if needed. - I also tried to swDeploy and the other available options with no luck via E-sys. Ultimately, I am not willing to spend $1600-2000 for a new head unit and have to pay additionally for the VIN to be matched/programmed after. If there is anyway for me to attempt to revive this head unit I will any and everything. |
Tags |
bmw, coding, f22, headunit, hub, m235i, n55, programming |
