10-19-2018, 02:37 PM | #45 | |
Rep 9,004
10-19-2018, 03:02 PM | #46 |
Rep 5,369
Keep in mind the OP in that thread is in Sydney, Australia. Apparently BMW has different tire pressure recommendations out there and I know many of their cars come with different tires than those spec'd in the US. They may also recommend different inflations to meet CAFE and make the car understeer more for the terrible US driving public.
Just experiment around see what you like. Keep in mind the tire pressure monitoring system is pretty sensitive and if you have too low a psi, it will lock you out of Sport/Sport+/DSC Off/Traction modes until you add enough air to the tires. My M235 seems to lock me out when the psi gets into the 28psi range.
Taskmaster2465.00 |
10-19-2018, 03:17 PM | #47 |
Rep 611
In case you aren't confused enough yet, my non-RFTs show 35/39.
2018 M240i 2WD w/AT
—Steve
'19 MX-5 Miata GT-S soft top Past BMWs: two '57 Isetta 300s, '70 1600, '72 Bavaria, '78 320i, '18 M240i |
Taskmaster2465.00 |
10-20-2018, 05:35 PM | #48 | |
Rep 442
So, if you want to start really low, like at 28 PSI, set that when your tires are cold. Then, run a TPMS reset. That sets a new base value that the alerts will trigger from. I recently did a track day in near freezing conditions. Tires were 26 PSI when I started, but warming to 34 PSI right where I wanted them after a fast lap. Because I set the TPMS RESET while they were at 26 PSI, I never had an issue. |
10-22-2018, 11:39 AM | #49 |
Rep 5,369
To go back to this power thing, I might be with you to some extent. I'm not power hungry and more importantly, I don't want to screw up the overall dynamics of the car. Last Friday I put my Dinantronics Sport to stock and I have to say, I'm really enjoying it. Yes, the car is a little slower, but the power is back to be very smooth and linear, more so than I remember. I can go full throttle in 1st and 2nd with much less worry of destroying the tires by the rapid torque surge. 3rd does feel a bit weaker and that is where I'm missing the power.
I'm quite surprised by how much the Dinantronics Sport affects the factory Sport throttle setting. When the Dinantronics Sport is in its Sport or Sport+ setting and you have the Sport throttle setting engaged, the throttle is hyper sensitive and it makes the 6MT rather difficult to drive. When the Dinantronics Sport is in its Sport or Sport+ setting and you're in Comfort throttle setting (Comfort, Traction, DSC Off), the throttle is actually laggier than stock. It's so weird and I guess I didn't realize this was happening until I put Dinantronics into stock (I've owned the device since March and never put it into stock). I was actually getting annoyed by how hard my 6MT was to drive smoothly with the laggy or hyper throttle. Now the 6MT feels great in the Sport throttle with the Dinantronics Sport off. Damn. I think now I'll just buy a catted downpipe (15whp/25wtq with no tune), work on the suspension a bit, and rethink any additional power adding modifications. Maybe I should just get a JB4 and set it to only add power in 3rd and the higher gears. I'll keep the Dinantronics Sport plugged in for the winter months when I can run it in Valet (-3psi) to help with poor weather traction.
10-22-2018, 11:40 AM | #50 | |
Rep 5,369
10-22-2018, 03:34 PM | #52 | |
Rep 9,004
I have a JB4 with Bluetooth adapter I'm taking off. If I upgrade, it will be BM3 with a custom flash for what your speaking of. |
