10-17-2018, 11:06 AM | #1 |
Rep 9,004
I'm actually not that interested in more power
The more I think about it, I'm not interested in that much more power with this car.
I mean, if it was there, I wouldn't say no - but the primary concern here for me is actually a power curve that's shifted more to the right (building progressively until redline) versus the massive impact of torque from low mid range that tappers off at 6500. And before any more power can be added, I'm really focused on dialing the suspension on this car. It feels soft, and the wiggle that it gets when it comes on power, the lean in corners, the bouncy rear suspension. I like the car, but these things...makes it feel a lot less sporty |
10-17-2018, 11:51 AM | #2 |
Rep 58
I am starting to feel the same way. Only have about 2k miles in mine, so giving myself another 3k or so to get used to how everything handles before altering the suspension. The suspension is definitely closer to what I want as-is than my previous WRX was out-of-the-box, which is nice.
Considering I can already spin the tires into 2nd if I give too much throttle, I want to work towards getting more of that power down, especially in cornering. Still playing with the throttle out of corners to get a smooth exit. I wish that there were more suspension options that would allow for maintaining the configurable suspension option for some of these rotten Houston roads that my wife rides along with me for... Since I got my car used, I will probably still get a JB4 first, more so I can actively monitor things better. |
10-17-2018, 12:00 PM | #3 |
Rep 58
10-17-2018, 12:04 PM | #5 |
Rep 9,004
10-17-2018, 12:14 PM | #7 |
Rep 58
10-17-2018, 12:23 PM | #8 | |
Rep 58
I've been wondering if that would help significantly. |
10-17-2018, 12:53 PM | #9 | |||
Rep 9,004
10-17-2018, 12:57 PM | #10 |
Rep 520
I have the “poormans” model which in England is an unnecessary luxury car but now that I’ve got that out of the way... the other day I went from 20 mph to the 50 mph limit of an average speed zone in what felt like less than three seconds. Track days here are populated almost exclusively by dicks, and good driving roads that aren’t clogged solid are 50+ miles from here. I am completely nonplussed at what I’m going to do with more power!
10-17-2018, 01:10 PM | #11 |
Newer 2er
296
Rep 474
Drives: 2017 M240i (Sold)
Wavetrac LSD, MPS4S 265 rears along with Dinan performance springs solved all the shenanigans in the rear for me, at least the way I use the car. Even with a shorter final drive (by 10%, 3.08 in the ZF auto) installed, I no longer spin the tires. It's a completely different (better) car now.
Oh, and I'm running a Dinan stage 1 tune with their CAI to boot.
2017 BMW M240i (Sold)
2021 F-150 Raptor 2017 Porsche 718 Cayman S 2017 Audi Q5 |
Texan2er20.00 Taskmaster2465.00 |
10-17-2018, 01:13 PM | #12 |
Rep 58
Taskmaster2465.00 |
10-17-2018, 01:23 PM | #13 | |
Rep 58
I have also sadly made the switch to the ZF with this car. Missing the manual, but for the commute it is a better option currently. Your setup may be pretty close to the path I end up heading down. |
mankid247109.50 |
10-17-2018, 01:52 PM | #14 | |||
Rep 9,004
BUt you're saying you don't have that squirrely behavior when you romp on it (even to over take)? Awesome. Quote:
10-17-2018, 02:00 PM | #15 | ||
Newer 2er
296
Rep 474
10-17-2018, 02:09 PM | #16 | ||||
Newer 2er
296
Rep 474
Yes, M Performance LSD is a clutch unit, but I understand it's pretty good for the money ~$2k. I just liked the idea of a purely mechanical unit not tied to the nannies.
Taskmaster2465.00 |
10-17-2018, 02:17 PM | #17 | |
Rep 5,372
I will say the suspension is actually pretty good on B road driving in Sport+ or DSC Off (i.e., stiff shock setting). Around town, it can feel a bit wonky and bouncy. You can tell the front end needs more tire. Adding the MP LSD a few months back made huge difference in traction in all situations and makes the car feel much more stable and results in more forward thrust vs wheel spin and fun-killing nanny involvement (the LSD often works faster than the traction control nannies). This isn't to say that the car still doesn't lose traction under heavy throttle in 1st, 2nd, and occasionally 3rd, but more power makes it too the ground and the car/power is FAR easier to control. The LSD is the real deal and you really can feel it, more so than any other LSD I've owned or driven with. It's surprisingly aggressive at lock-up. The MP LSD is a must and should be the first thing on your list. The only downside to the LSD is that it makes you very aware of how soft the rear bushings are as the additional traction results in more apparent squirm in the body as the LSD does its thing. I'm running 18X8 et43 Alutec Drive wheels with the OEM staggered MPSS tires. The Drive wheels allow me to run 245/35R18 with no clearance issues. Next spring the OEM MPSS tires will be replaced with a square 245/35 MPS4S setup. Running the 245/35 in the front vs the stock 225/40 will give me nearly 1.5" wider tread. That should help in grip and reduced roll. Next spring I'll also be adding Dinan springs with the Dinan 1/4" rear lift spacers. But I'll only run the springs in the rear. Dinan rear springs are 30% stiffer than stock and drop the rear 0.75" with the spacer. The increased spring rate and reduced spring travel should help alleviate the rear axle pogoing and other better control. The front Dinan springs lower the front by 0.5" and only add 10% more rate which is nothing. I find the front axle fine and low enough in stock form. I'll see how the car behaves with the square tire setup, rear springs, and a more aggressive suspension alignment before considering to install the front springs.
Taskmaster2465.00 |
10-17-2018, 02:18 PM | #18 |
Rep 610
Refreshing topic
I have a 4 pot and I'm really happy with the msport suspension. (Non tract pack) But I really think the rear would be much more planted with an LSD. |
Taskmaster2465.00 |
10-17-2018, 03:03 PM | #19 | |||
Rep 58
Makes sense. I've seen several recommendations to do the bushings at the same time as the LSD, I assume to immediately rectify this. |
10-17-2018, 04:04 PM | #20 | |
Rep 611
If BMW repeats that promotion, it'd be heck of a nice savings.
—Steve
'19 MX-5 Miata GT-S soft top Past BMWs: two '57 Isetta 300s, '70 1600, '72 Bavaria, '78 320i, '18 M240i |
10-17-2018, 04:05 PM | #21 | |
Rep 9,004
Typically BMW's run low spring rates in the front (150lbs/in -170lbs/in) so you're correct, a 10% increase would be minor. My guess is they did just enough to prevent bottoming out during normal driving due to the decreased ride height. One of the first things I want to do is move to a square setup, close to my E92 which was 255/40/17 all the way around (great for tire rotation too) and provided plenty of grip. The odd offsets on this car are actually really annoying, and I hate the thought of having to run a spacer. Did you change the rear subframe bushings? Are the M2 versions any better than the M235is? |
10-17-2018, 05:34 PM | #22 |
Rep 9,004
Do you know the part number off hand?
