2Addicts | BMW 2-Series forum Technical Topics Wheels and Tires -- Sponsored by The Tire Rack Please HELP: how to avoid loosing OEM wheel center caps? :(
      11-04-2014, 08:02 AM   #1
AlexGT
AlexGT's Avatar
Guatemala
420
Drives: G05 X5 MSport
Hello everyone. Just a week after I received my M235i, I lost/drop a center cap, I first thought it was stolen, but then I found out that the other M235i that was sold in my country, had the same problem. Today, I lost another one (it has happened only with the front wheels) Every time I step out of the car, you may found this funny but I hit those two center caps with my hand and I always hear a "click" sound.... I forgot to do this for like 3 days and now I lost a center cap again
Has anyone experienced this? My local BMW dealer told me that it was a factory issue, he replaced the first cap I lost for free, I don't know if they're going to replace it again without a charge
Should I go and put some super glue on them? I truly don't know how to avoid this from happening anymore
      11-04-2014, 09:23 AM   #2
whoosh
Higher than you
whoosh's Avatar
Drives: M235i xDrive
I just had two rear caps replaced at the dealer, just over a week after taking delivery. The caps were lost within two days of getting the car. I glanced at the replacement caps and they don't seem to have provision for the steel ring inside to keep tension on the tabs against the inside of the wheel bore. Maybe I just didn't see it...
I don't know about super glue - you want to be able to remove the caps if necessary. Maybe used sparingly and in a way that it could be cut/trimmed to allow the cap to come out. A very small dab of silicone adhesive applied from the inside with the wheel off the hub may be a good option. For now I'll just pound the caps in after each drive too.
Current: '15 M235iX | '15 Macan S | '00 Honda S2000
Notable Previous: '12 E92 335is | '10 STi | '88 E30 325iX
      11-04-2014, 09:28 AM   #3
five3three
Drives: m2c
Couple of threads about this already along with suggestions...
http://www.2addicts.com/forums/showthread.php?t=998353
http://www.2addicts.com/forums/showthread.php?t=1020076
      11-04-2014, 10:42 AM   #4
whoosh
Higher than you
whoosh's Avatar
Originally Posted by five3three View Post
Thanks for the references for further reading. :beer:
      11-04-2014, 11:58 AM   #5
horsepower_and_hounds
Drives: BMW
I took the spares from my 1 series and they work perfectly
      11-04-2014, 12:51 PM   #6
AlexGT
AlexGT's Avatar
Guatemala
420
Man I hate this, thanks for the reply. The curious thing is that the ones from the M135i (which is sold in my country too), don't have this problem, even that the wheels are the exact same model as on the M235i
Anyway, I see that we will need to keep on pounding them regularly until we decide to go with another type of wheels
      11-04-2014, 12:52 PM   #7
AlexGT
AlexGT's Avatar
Guatemala
420
Thanks five3 for sharing those links
      11-04-2014, 12:53 PM   #8
AlexGT
AlexGT's Avatar
Guatemala
420
Do you happen to have the part number for the 135 caps? Thanks man
      11-04-2014, 05:39 PM   #9
escobar929
escobar929's Avatar
154
Drives: M2 CS
2020 M2 CS  [10.00]
2020 M240i  [0.00]
wow, thats crazy, didn't even know that could be an issue
      11-04-2014, 06:39 PM   #10
Drives: BMW
Link to my post showing the old and new caps...I think you can read the p/n
http://www.2addicts.com/forums/showt...1020076&page=2
      11-04-2014, 08:17 PM   #11
AlexGT
AlexGT's Avatar
Guatemala
420
Thanks a lot!!!
      11-05-2014, 07:08 PM   #12
mike@tpc
Drives: white M235i
just use some clear rtv silicone on them
      11-05-2014, 07:20 PM   #13
AlexGT
AlexGT's Avatar
Guatemala
420
Thank you mike, I'll see if I give that a try
