06-01-2023, 06:51 PM | #1 |
Rep 232
Coding for BBK Retrofit
Hi,
I have recently fitted a cheap BBK solution (I can make a guide for this if there's a lot of interest) to have the 380mm rotor (OEM F8x) up front. I have followed the guide from the F30 forum. I am able to VO code the SPBR and remove 2NH, but I am unable to edit the rotor sizing in the DSC. I see this instead: I was expecting to see the numbers like here: Could it be because my firmware is too new? The version I am running on is November 2021. |
06-01-2023, 09:36 PM | #2 |
3726
Rep 3,632
Your selection is under bremssattel which translates to caliper, whereas the brake rotor size is under bremsschiebe, which translates to brake disc. I wouldn’t expect the brake disc/rotor size to be in the caliper section.
06-09-2023, 05:00 AM | #3 |
Rep 79
Hi LanceM26,
I have a feeling that the CAFD mapping you are using is too old. This is another way of saying that your firmware is too new. In other words, since the DSC is from 2020, the values that are mapped inside the CAFD file (the one you edit in that view you screenshot) do not correspond to those read by your Launcher (Maybe you use Launcher PRO 3.7 or 2.8.1). One quick solution (albeit expensive) is to use a CAFD mapping tool that is new enough for you to see values that were introduced in 2020 or in recent years. BimmerUtility is a good example. If you want you can send me a PM with the CAFD file from your DSC attached and I can tell you if with BimmerUtility I see the values you're looking for. At least, if that is the case, you don't waste 99 USD buying a tool that you don't need. And yes, the value you are trying to set should be C_Variante_Bremsscheibe_vorne_e. |
06-09-2023, 10:38 AM | #4 | |
Rep 232
06-09-2023, 12:35 PM | #5 |
Rep 79
06-09-2023, 12:36 PM | #6 |
Rep 232
06-09-2023, 01:38 PM | #7 | |
Rep 79
06-09-2023, 01:53 PM | #8 | |
Rep 232
boldorider413.00 |
