Will my car be ok if i fill up E85 from the pump if it's testing a less than 85? |
07-21-2021, 10:18 PM | #1 |
Rep 93
hi so i was wondering, so i wanna run the e30 tune on bootmod3 but people are saying that in arizona, e85 is more like e60 or so. I'm in a FB group that shows ethanol tests from gas stations from the past 2 days at pumps and some are testing like 90-100 or so, so i might try those stations and the tests were from 2 days ago. i'm just kinda nervous anyway about filling it up. I wanted to fill up before my ethanol tester comes so i can test out the tune. If the E85 was like E60, would anything happen to my car if i only run it the first time as that? (people have posted pics of test kits of the pump testing 85+ from the past 2 days at stations around me so i was thinking of using that just for the time being just once)
Thank you!! |
07-22-2021, 11:28 AM | #2 |
Rep 142
Just use an E85 mix calculator and change the Ethanol percent to whatever percentage that station tested to.
Google E85 calc Also tunes adjust timing if sense knock, so drive easy for 5 miles or so and then you can go full throttle for it to learn octane/knock threshold. Last edited by ctt300; 07-22-2021 at 11:34 AM.. |
07-22-2021, 12:40 PM | #3 | |
Rep 93
07-22-2021, 12:59 PM | #4 | |
Rep 93
