07-20-2021, 06:13 AM | #1 |
Rep 189
Very slight sound when lifting clutch
Hi,
6 speed manual with factory lsd. I get a very slight clunk when lifting the clutch while shifting. Normal? It almost sounds like a "delay" of a part engaging. |
07-24-2021, 10:00 AM | #5 |
Rep 189
07-25-2021, 09:54 PM | #6 |
Rep 351
07-26-2021, 12:49 PM | #8 |
Rep 4,134
Mods: Yes.
07-26-2021, 03:04 PM | #9 | |
Rep 5,369
Unfortunately checking and fixing these issues aren't particularly easy unless you're fairly good at working on cars in very confined spaces and contorted on your back. I've installed the Ultimate Clutch Pedal which replaces the entire clutch pedal assembly so I know how the system works and have seen what's lubricated from the factory. Install took me well over 3 hours, but I can now remove/reinstall/adjust in 10 to 30 minutes. The attached directions will give you an idea of the lubrication points and over/center spring assembly: http://www.ultimateclutchpedal.com/instructions/ The attached link shows the clutch pedal bushings (part #35006878303) and the over/center spring assembly in the clutch pedal assembly diagram: https://parts.bmwnorthwest.com/p/BMW...006878303.html
