07-14-2021, 12:31 PM | #1 |
Rep 90
Drives: 2020 X5; 2016 M235i Conv. 6MT
BM3 Flex Map
Hi all, just started messing around with BM3. So far, I've loaded up the M2 0+ map and haven't decided what else to try. I'm leaning towards Stage 1 93, but am curious what experiences people have had with the FlexMaps that allow you to do a hot-swap of maps. Any advice/comment would be appreciated!
Thanks! Last edited by DBinOH; 07-14-2021 at 01:51 PM.. |
07-14-2021, 01:30 PM | #2 | |
Rep 196
I am on stage2+ and don't use racegas, only E30, so it is useless to me. However it will be very useful when I get custom tuned and can have a 93 and E40 map in the same catalog to switch from. Right now you can only choose maps for the same fuel, but different map, in stage 1/2 Stage 1 maps can be run regardless of mods, I highly recommend you flash to the stage 1 multimap and try each. The 0+ is basically a stock map with little more top end. Stage 1 will be a noticeable improvement over it. Just make sure you have good gas, fresh plugs, etc and LOG. There is plenty on here to get a basic understanding of logs and how to chase down the little issues you will find as you move up the maps.
14' Alpine White M235i 6MT, BM3 Stg2+, VRSF DP-CP-FMIC, Dinan Muffler, GFB DV+, 3.5 bar MAP, Dorch Stg1 HPFP, NGK 97506, BM3 Flexfuel Kit, CDV delete, KW V3, EDC delete, Powerflex Camber LCA bushings, VMR 801 18x8.5/9.5 et45, Conti Extremecontact 235/265
Next step: M2 Competition or Manual Supra MKV build Summer 2022 Last edited by rtl32; 07-14-2021 at 01:36 PM.. |
KennyFSU1104.00 |
07-14-2021, 01:53 PM | #3 |
Rep 90
I haven't really done any mods other than a new CP and the MPE. Using 93 Octane, primarily from Costco.
07-14-2021, 02:17 PM | #4 |
Rep 87
Stick to the Stage 1 91, 93 or M2 maps. 93 is quite a bit better than 91, as I found 91 to have a lag problem when overtaking on the highway. Either way, enjoy!
Chris |
