07-10-2021, 11:18 AM | #1 |
Rep 395
N55 manual highway MPG?
Hey guys!
how much are you guys getting on the N55 manual MPG on a highway? I went on a trip recently and got 22.5mpg on a highway. Felt a little low, but AC was on the whole trip and it was (literally) 110F/43C outside. I was quite shocked with so low MPG, esp because I drove most of the time at 60mph and 6th gear... I asked my friend who has a B48 330i 8AT, he said he got more like 30mpg on a similar trip. More horses drink more? Also, I tried to use the search function and got overwhelmed w/ tuning results... :P My car is bone stock. Last edited by rainfall; 07-10-2021 at 11:25 AM.. |
07-10-2021, 11:52 AM | #2 |
Rep 205
My b58 manual gets more like 33 us mpg (6.7l/100km) on the highway. The 4 banger will do better and the auto box is also better.
22.5 seems low. The easy things to look at are tire pressure, air filter, 20w oil, spark plugs, no ethanol fuel. |
07-10-2021, 12:02 PM | #3 | |
Rep 3,496
In a 12/19 thread on M240i mileage, I posted the comment below describing the mileage I'd received to-date from my M240i. I expect the N55 would be reasonably close to a B58 when it comes to gasoline mileage. "I get low-to-mid 30s from my MT M240i on the highway. That's when driving at 68-72 MPH with just me in the car and with the tire pressures set to the manufacturer's specification. I get 28-30 MPG if I run the car at 75-80 MPH. At 6,350 mostly highway miles, I've averaged 30.7 overall since new. That was based upon the gallons reported by the pumps and the car's odometer reading." Those 6,350 miles were probably 90% highway miles.
rainfall161.50 |
07-10-2021, 02:56 PM | #6 | |
Rep 395
Someone had asked about the tire pressure, I think it was calibrated. I remember checking tire temperature in the trip and I think the pressure was normal |
07-10-2021, 04:55 PM | #7 |
Rep 5,577
I just did round trip Baltimore to north Philly-area about 120+ miles each way.
Temps range was varied because I left 7:00am and returned mid day with temps in the mid to upper nineties. My tire temp were about 37 front and 44 rear when hot. Eco Mode heading up Comfort heading back. about 2 hours 20-minutes each way and some idling due to construction and Kia Soul blowing-up. My speed going back were high. I was overall in the low 20's for overall mpg. |
rainfall161.50 |
07-10-2021, 11:21 PM | #8 | |
Rep 274
The only explanation has to do with change in the fuel quality. I was consistently getting 29-31 MPG. Now, 27-28 and my tires inflation is on spec. If I drive just a bit more in town, it even go down to 23-24. I always use Premium from new and I have only 17K with no mods. Don't look for any other reason than fuel.
2019 M240i, Melbourne Red, Black Interior. 3M Tint, Premium Package, Harman Kardon, Adaptive LED Head Lights, M Performance Exhaust and Diffuser, Chrome Exhaust Tips, 719M Bi Color Wheels, Black Kidney Grille, Burger Tuning JB+.
07-11-2021, 05:36 AM | #9 |
Rep 1,219
Drives: 2015 M235ix
A/C both cools and dehumidifies the air. Both functions consume energy, which in a car comes in the form of fuel. The more you do both, the more energy you consume. That is why the A/C is reduced in eco-pro mode.
I agree that fuel quality is likely a factor, as is tire pressure, but so is the fact that OP was using the A/C to reduce the ambient air temperature by 40 degrees F. BTW, driving without A/C is not a solution, since then the windows are open for ventilation, which increases drag, which increases cost. |
07-11-2021, 10:39 AM | #11 |
3621
Rep 3,590
A medium sized air conditioning unit on a car such as an F22 will have a capacity of about 6kW or 20,000BTU/hr. In steady state cruising at 96km/h / 60mph the car will be consuming about 11kW of engine power with the AC off on level ground, using 17kW at maximum AC capacity is equivalent of adding 16km/h of speed to 112km/h / 70mph.
The F22 is certainly capable of 30 US mpg at 60mph, but the fuel economy at 70mph shouldn't drop off by more than 1mpg or so. I would say 22.5mpg due to just flat out usage of the AC indicates a problem elsewhere other than just AC usage. In my experience I can get 7.5 l/100km in our M240i at a steady 100km/h (31mpg) and calm conditions, but it doesn't drop below 8.0 l/100km (29mpg) in high ambient temperatures with blustery winds. |
dradernh4392.50 |
07-11-2021, 10:58 AM | #12 | |
Rep 77
1) Different parts of the country run different fuel blends and those also can change between a summer and winter blend. Perhaps you have lovely CA gas like me. I don't have my 240 yet but i do know I got worse mileage here than when the lived on the east coast when I moved my previous cars. Blends impact mileage to some degree. 2) what's the status of your air cleaner/intake? Blockages/overly dirty filter could impact mileage. |
rainfall161.50 |
07-11-2021, 01:22 PM | #13 |
Rep 5,577
Just came back on the beltway and had the 235 in Eco Pro and the real time MPG reading on the display between Speedo and Rev-counter.
I get the impression if I cruised at 60'ish-mph and did not included urban driving or idling in backups, I could maybe achieve high 20's or maybe even 30 mpg for an interstate drive. |
07-11-2021, 05:19 PM | #15 | |
Rep 3,496
I'm on the higher end of M240i fuelly data with 28.9 mpg after 11,953 miles.
07-11-2021, 06:00 PM | #16 |
Rep 91
Drives: 2020 X5; 2016 M235i Conv. 6MT
Just finished a 5 hour drive in the hills of upstate NY. I’ve got a 2016 M235 6MT. Averaged around 29 mpg. I’m pretty careful to fill with 93 oct, but I can’t imagine it dropping that much from octane or AC. Are you sure you weren’t accidentally in Sport+ the whole drive?
07-12-2021, 08:28 AM | #17 | |
Rep 515
For example, if Im cruising at 80mph with my shitty CA's gas, I usually avg around 28-29 mpg. If I do a tad spirited driving, a little bit hard acceleration here and there(10%ish of the way), this easily drop the avg down to 26-27 mpg ish. If you are flooring it quite a bit here and there, that can easily take it down to 22mpg. (Not saying this is your case, just a possibility for you to scratch out) |
07-12-2021, 07:51 PM | #18 | |
Rep 274
07-12-2021, 08:03 PM | #19 | |
Rep 274
07-13-2021, 09:35 AM | #21 |
Rep 5,577
07-13-2021, 10:18 AM | #22 |
Rep 148
When I had my 335i I got around 32 ish from Las Vegas to Los Angeles. When I drove it to work (13 miles) I was getting around 35 ish. The 6th gear was really high on those, I believe it's around 3000 rpm.
