06-20-2021, 12:12 AM | #1 |
Rep 216
Drives: 2016 BMW M235i
Hey guys, I have a pretty huge problem…
So earlier today I got my methanol kit working and everything ran smoothly. Although I wasn't really getting any bigger boost so I pulled over, turned off the car, purged and started the car, thinking that there was just air in the lines. Although, after that the car threw a drivetrain malfunction. Nothing too bad and the car was drivable. Unfortunately I had a very important event I had to attend and had to take the car on an hour drive later that day. After I came back to the car to go back home, the car stalled and sputtered several times, even moving. I also heard a slight ticking sound (really hoping it's not knock) from the engine. Also unfortunately, it's extremely late and I had to be home so I couldn't get much more information other than the codes. Any help would be very, very appreciated. (Also noticed my IAT temp on the JB4 app read "0", methanol would not show up on the graph and couldn't be enabled, and my AFRs were going crazy. Thanks again for any help.
06-20-2021, 12:13 AM | #2 |
Rep 216
I also smelled gasoline from the exhaust while the AFRs were ranging from 15 to 0…
06-20-2021, 12:24 PM | #3 |
Rep 225
Do you have any logs from the JB4? Are you using map 3 or a different setup?
18 340i F30 mostly stock |
06-20-2021, 12:25 PM | #4 |
Rep 216
Well I switched back to Map 0 after the malfunction. And I don't have any logs because the car would not run long enough to get a viable log.
06-20-2021, 01:08 PM | #5 | |
Rep 225
06-20-2021, 03:00 PM | #6 | ||
Rep 216
06-20-2021, 05:31 PM | #7 |
Rep 225
You can disconnect the MAF. If the car runs better check for leaks.
06-21-2021, 11:57 AM | #8 |
formerly M3AN 46
14
Rep 69
What kind of controller are you using for the meth? Hopefully a bms fsb. Are you running a solenoid? If not, you definitely want to. Also, check all your jb4/meth connections again, sounds like you hooked something up wrong. Without a solenoid, your meth could be "leaking" while the car isn't running, which will cause all kinds of issues when the car is started, essentially flooding the system with meth.
