M235i Winter Tires - Square tires on Stock Staggered Wheels? |
10-25-2020, 04:06 PM | #1 |
Rep 7
Hello everyone!
I currently live in Colorado and it has started to snow so I'm planning on putting winter tires on my stock 436M M235i wheels. I understand that the wheels are 18x7.5 and 18x8 but I want to put 225/45/r18 all around. Will this work? Any other tire size recommendations? Thank you in advance! |
10-25-2020, 07:57 PM | #2 | |
Rep 42
10-25-2020, 08:05 PM | #3 |
Rep 444
I run 225/40/18 Michelin X-ice Xi3's on the stock staggered rims in winter. Its completely safe, and the narrowness is desirable because it helps ever so slightly with traction.
10-26-2020, 11:58 AM | #4 |
Rep 1,115
I just made my stock staggered wheels my winter set after running 17s for 6 winters. Went with these sizes, I highly recommend, you get a bit more sidewall and more tire choices. Tires are Michelin Pilot Alpin PA4.
215/45/18 245/40/18 The diameter of the two is almost identical. You get more sidewall to protect your wheels and about an inch more ground clearance. You could go square setup, but I think staggered with a bit wider on the rear is good when driving on dry cold pavement 90% of the time. |
10-26-2020, 01:51 PM | #5 |
Rep 3,496
Help me out, here; it's a 1/2" increase in ride height, isn't it?
Pray for Mojo429.50 |
10-26-2020, 04:49 PM | #6 | |
Rep 1,115
Front to back your diameter variance is only 0.38%, so even X-drive guys could run this setup. |
dradernh4397.00 |
