03-09-2017, 02:10 AM | #1 |
Rep 49
Potholes - what to check after?
2015 M235i ZF8 with 31.3K miles (bought it CPO from dealer a month ago with 28.4K miles).
Last weekend, hit a pothole while in Sport mode on right front tire at about 40mph (no braking). Heard a bang sound as it hit - guessing that's the suspension fully compressing. Running 18" stock wheels and PSS tires - 225/40/18 at the front and 245/35/18 at the back. The 225s up front were newly installed by dealer when CPOed. No tire or wheel damage, TPMS is OK, no vibrations at speed or pulling left or right. Is there anything else I should check for? Bay Area road quality can be a real bitch sometimes. |
03-09-2017, 07:28 AM | #2 |
Rep 780
I hit minor potholes driving in the city where I work, stuff that didn't even raise an eyebrow and my rims looked fine. Turns out I had my rear bent to hell and i only found out when getting the tires rebalanced since I had a verys slight vibration.
03-29-2017, 12:42 AM | #3 | |
Rep 12
No suspension damage, but even after balancing and realignment, some things are not right. I think that the balancing needs to be rechecked (oscillating vibration at certain speeds) and there is also this slight tendency to "shift" one way or the other (like when driving on a road surface that is grooved). |
03-29-2017, 05:47 AM | #4 |
Rep 129
Drives: 2016 MW M235xi
I hit this a couple weeks ago (the plate collapsed while driving over it). Huge thud sound. Had a blown tire, cracked rim, and a tiny bit of damage to the side skirt but there was no suspension damage. If you didn't even pop a tire and it seems to drive fine, I wouldn't worry about it but an inspection can't cost that much.
03-29-2017, 11:41 AM | #5 | |
Rep 566
10-10-2020, 10:06 PM | #6 |
Rep 5
I recently hit a pothole going around 100km/h, heard a loud bang as I hit so I immediately pulled over and to no surprise I blew my front right tire. Rim was bent a little as well but barely noticeable to the naked eye. Real issue is I now have negative camber on that wheel. Car isn't pulling to a side or vibrating but there must be something broken or bent on the right front side...
10-11-2020, 09:25 AM | #7 |
Rep 2,869
FWIW, I just had one of my tie rod ends snap while they were doing the alignment, and I suspect it is the result of cumulative hits like this. It just snapped when they were adjusting it. It looked like a stress fracture starting in the first few threads, no significant corrosion or direct impact damage. Probably could not be seen beforehand without magnaflux, but if you've taken a hit that makes such a visible change (blowout, bent rim, or visible alignment camber) I would have things looked at closely. I've hit things hard enough to feel like it bottomed out a few times, but never blew a tire or bubbled a sidewall, never knocked a wheel out of true.
Jllor970.00 |
10-11-2020, 09:47 AM | #8 | |
Rep 5
10-11-2020, 10:42 AM | #9 | |
3612
Rep 3,578
- Check the top of the strut tower to see if it is flat or has been distorted into a dome shape. - Confirm the car sits level from side to side to confirm the spring hasn't been damaged by measuring the wheel arch high point to the lowest point on the wheel rim. - Inspect the suspension upright and compare with the other side to look for cracks and distortion - measure the angle between the brake rotor face and strut body to confirm distortion. |
POMFKIMOCHI38.50 |
10-11-2020, 01:27 PM | #10 | |
Rep 5
