2Addicts | BMW 2-Series forum Technical Topics N55 (M235i) Engine, Transmission, Exhaust, Tuning JB4 - Rail Pressure Sensor Fault Codes Help
      09-15-2018, 04:51 AM   #1
R3LMV
Australia
Drives: N54 135i
Hey,
I had my JB4, BMS intake, Scorpion downpipe, Forge Intercooler, Forge Chargepipe installed yesterday on my M235.
I've had drivetrain malfunction errors quite a few times and the car is hesitant for a while. I checked connections and everything seems perfect, these were the codes I received:
180001 - catless downpipe detected
102001 - Air mass, plausibility - Tuner code, ignore
119002 - Rail pressure sensor short to ground
101F01 - Throttle valve opening angle pressure - ignore, tuner code
119404 - rail pressure sensor, signal stuck
I've scrolled through a million threads and there doesn't seem to be a clear answer?
Map 2 settings
Boost Safety 20.0
Default Wastegain Position 0
PID Gain 10
Auto Shift Boost Reduction 10
FF/ Wastegate Adaptation 60
Fuel Open Loop 50
The rest below were 0
Tmap Voltage 1.92
Firmware Ver 10/12/15
Interface Ver 4/1/18
VIN ..........
Country UK
Avg lgn 2.4
The rest below 0
Can anyone please help
      09-18-2018, 05:36 PM   #2
Mike@N54Tuning.com
Drives: 2007 335i, 2015 M3
I'd update to the latest firmware, but if the fuel pressure fault returns it's either an issue with that JB4 connector, a software setting, or the sensor itself. You could put just that connection to stock to rule out the sensor being an issue.
Mike
R3LMV6.50
      09-19-2018, 12:03 PM   #3
R3LMV
Australia
Drives: N54 135i
Mike
Afternoon Mike,
So after doing some logs the other night I sent them to BMS and they saw no issues but I told them the car is temperamental with problems and the other night it was running well. I start the car today, drivetrain malfunction straight away I restart the car and it clears then I and hesitation and jerks happening. If I try and put my foot down half way it stutters and drivetrain malfunction again.
Mods installed last weekend all new parts :
JB4, scorpion downpipe, forge intercooler, forge charge pipe, BMS intake
Also latest firmware updated.
Any ideas?
